Which setup?
Old Sep 27, 2004 | 12:40 PM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
Which setup?
Allright I am sick of my six banger and found this place here in florida that has great deals on Camaro engines all types.
Now my question is what do you guys think i should put under the hood in place of the little 3.1:
350 TPI Auto
LTI Auto
LS1 Auto
I would have to save up a little more for the LS1. But what do you guys think???
Old Sep 27, 2004 | 01:01 PM
ll-84camaro-ll's Avatar
Car: 91 Z28
Transmission: 4l60e
thats a tough 1 because LS1's are nice but you could probly get a 350 TPI and use the left over money you would have spent on the LS1 and use it for performance parts and get that 350 running pretty fast.
Old Sep 27, 2004 | 01:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You need a lot more than the engine, because basically nothing currently attached to your V6 will work with any of those engines (you can probably use the radiator with the TPI engine, and possibly the in-tank fuel pump - that's about it).
You need everything from the car out of which the engine comes to make it run, as well as the engine and transmission. Other things to consider: 1) who's going to do the work (any of the options would involve substantial labor, with the cost increasing as you go down the choice list); 2) how much over the end value are you willing to spend - all will cost more than the car will be worth when complete, especially if you pay to have the install done; but again, that amount increases as you go down the choice list.
Old Sep 27, 2004 | 01:57 PM
Engine: 383 Stroker
Well for $1200 i get everything i need. And when i say everything i mean to the last detail. And i have friends that will do the work for free.
Old Sep 27, 2004 | 02:11 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
motor mounts
crossmember (LS1 swap)
fuel pump
headers
exhaust
wiring
tranny
engine
only cost $1200 installed.
My friends wouldn't eat that much cost. It will cost much more than you think even if you get great deals.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
