400 SB Suggestions
Old Oct 6, 2004 | 05:43 PM
Dante's Avatar
Car: 92 RS
400 SB Suggestions
Im going to be swapping a 400 sb into my 92 camaro but im looking for suggestions on the setup of the engine. The application will eventually be turbo and spray but are uncetain as to what parts to build my engine with for the best performance.
Old Oct 6, 2004 | 06:58 PM
Drakar's Avatar
well if your doing turbo and spray I would suggest forged and low compression.
thats all I can help
Old Oct 6, 2004 | 11:50 PM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
Is it gonna be street legal,and to what degree?
Old Oct 7, 2004 | 01:05 PM
OneLongProject's Avatar
Car: 1987 Z28
I'd build a 421sbc with it.
Eagle has a nice 4340 Forged crank for only $665.71.
Just use a 3.875" stroke crankshaft
Using the 4.00" requires quite a bit of machine work and costs almost $300 more.
There's a really nice 3rd Gen T/A at the drag strip here running a 421sbc.
I see him pretty often, I know he's using a GM 400 block with the 3.875" Eagle crank.
Just my
Let us know what you're goals are.
Turbo- EFI or Carb?
Spray- How much nitrous you plan on using?
Old Oct 7, 2004 | 01:56 PM
Dante's Avatar
Car: 92 RS
what modified car these days are actually street leagal, not many are 100%. But im going to try to keep it as legal as possible.
Old Oct 14, 2004 | 03:08 PM
TonyP455's Avatar
Car: 1986 Trans Am
Engine: 305 Carbed
Transmission: WC-T5
Im doing the same thing as this guy, I wanna run a cc carb, and spray 150 shot most of the time but maybe 250 shot
I wanted to know how much I could stoke it up to. I was told 427, but with the 4" crank prolly does need work done to the the block. 421 sounds like a good idea.
I was thinking of using Edlebrock Prefromer RPM head cam and intake.
Is that a good idea?
any suggestions, I already have the block, my goal is 500 hp as streetable as possible, b4 the nitrous shot.
Old Oct 30, 2004 | 03:52 PM
z28freak84's Avatar
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
if you build a 421ci use AFR 210 or even the 220cc heads.
Call a cam manufacturer for the cam
Old Oct 30, 2004 | 06:45 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Spend the money wisely on the heads since they dictate your power. Defineatly wil not go wrong with AFR's. If your going to build a 421cid the 210's are about maxed out for NA power that does'nt require alot of block work and specialized valvetrain. Anything bigger cubic inch wise you should look at the 227's.
Only things flowing close to AFR out of the box are bigger Dart Pro 1's that have been worked over as well as Brodix,... Edelbrocks's are'nt even close. So you will be money ahead buying AFR's that flow waay more than other brands that will require yet another investment to have somebody work them over.
Your gonna want the strongest shortblock possible if turbo plus spray so forged is obvious. Achieveing 500hp N/A is pretty simple and with the right components easily streetible. Jsut takes money to do it so it's reliable 500hp.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
