Couple ?'s
Old Oct 22, 2004 | 08:56 PM
black90rs's Avatar
Car: 82,84,90
Engine: camaros
Couple ?'s
ok i got a 91 rs with a 3.1.. Well im bout to swap in either a 350 or 305 tpi.. I read the sticky at the top and it says i need to change alot of stuff.. Well i was told that the harness was the same except i would have to lengthen some connections and add 2 more injector wires.. Is that something easy or would i be better off just getting a harness from a donor car? Also i heard i could use the v6 ecm and just change the chip.. Im getting the engine for really cheap (bout 2-300) and the v6 is on its last leg so im looking for alternatives.. And right now this is the cheapest.. And yes i did
Old Oct 22, 2004 | 11:31 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Get a V8 harness and ECM.
Old Oct 22, 2004 | 11:45 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
yes get the harness, certain yrs could just swap the chips in the ecm, but you should do another for which ones (I don't think the 3.1 was one of those)
Old Oct 23, 2004 | 03:23 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Dont sound like too good of an idea when the ecm is exactly the same........
Old Oct 24, 2004 | 05:31 AM
black90rs's Avatar
Car: 82,84,90
Engine: camaros
ok so the ecm is the same? so all i would need to get is the engine harness from a v8 car?
Old Oct 24, 2004 | 11:23 AM
Engine: 5.7 / 7.4
you swap the prom chip.
Old Oct 30, 2004 | 07:11 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
ECM is same, chip is different, dependent upon which motor specifically the car got, you could modify your harness.
You may want to look into swapping an LT1 instead of a tpi motor.
Old Oct 30, 2004 | 07:47 AM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
Dont listen to tommy, his way to resolve anythign is "swap in an LT1"
hehe you know im kiddin you, tommys very good with the turdgens, id take his advice, but id say on a budget lt1 will be alot of headaches and pretty pricey.
btw tommy we need to get out to the track, i saw your girls RS around the other day, doesnt sound to "crazy" exhaust wise.. im sure ill give her a run.. except i burn tires all the way through 2nd gear and half in 3rd lo, still havent been to the track though, i tried to go a few weeks ago and i got there late, they wouldnt let me run.. hour drive for nothign lemme know trhough, i NEED to get to the track sooooon.. i need some adrenaline hehe
rep the turds!
Old Oct 30, 2004 | 09:26 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
rep the turds!
Careful that thing doesnt do jack until its manually shifted you saw her running around in OD, it shifts at a lame 4500 and dont do jack, it wakes up a bit when you drop it into first and dont touch the shifter till the needle is about at its end
An LT1 is a lot less headaches than most thing, and can be done quite cheap if someone actually wants to do so.
Old Oct 31, 2004 | 08:51 AM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
actually, i was at waters/anderson turning left on anderson, she was coming down anderson turning left on waters, so she drove rigth past me when i was waiting for the light, she was only in 2nd and it was loud yea but not anything like my loud :P
\im eager tho to run it.. but spinning tires throguh 3rd gear isnt gonna help me much but, maybe on some sticky tracks ill hook decent.
Old Oct 31, 2004 | 09:21 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
loud for a manifolds and 2.5" exhaust car though
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Linson
Oct 1, 2015 09:50 PM
