LT-1 Question???
Old Nov 14, 2004 | 01:09 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
LT-1 Question???
i just did a search on the LT-1 swap and there are alot of good things to follow but not the thing im looking for. I really want to do this swap!!! But is there any way i could use my wiring harness and burn a chip for my computer in order to run the LT-1 or do i have to get the the LT-1 harness???? and couldnt i use my 305 acc brakets for my AC, Alt, Power steering pump ect.... let me know!!!
Old Nov 14, 2004 | 02:22 AM
TexasLT1's Avatar
Car: '92 RS
First off, its LT1, not LT-1.
Second, good luck trying to burn a prom and get your thirdgen ECM to work with the optispark. Not going to happen.
Third, someone has done the swap and kept his thirdgen accessories, but I can't remember who it was. IIRC it was a pain in the ***.
Old Nov 14, 2004 | 10:05 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
sorry for the miss print but do you think its possible to put on the acc on the LT1??? isnt it the same 350 motor just with a little bit more punch to it??? so for sure i have to get the harness. how long will that take to do??
Old Nov 14, 2004 | 01:43 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
The block isnt even the same, the water pump area is different, do yourself a favor and get the front accessory's with the engine, and yes you need the harness / computer. You'd be looking at more headaches and $ making the stock ecm/harness work with the engine.
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
