350tpi to LT1 questions
Old Nov 15, 2004 | 04:47 PM
Incoming's Avatar
Car: 1986 Firebird T/A Streetracer
Engine: V8 350TPI
Transmission: Modified 700R4
Does anyone have info on the stock LT1 hp.. also if i swapped in a LT1 could i use this kit on it?
http://store.summitracing.com/defaul...4922130+305334
im just trying to get the most power for my money and alot of people are all for the LT1. my engine is acting up and i dont really wanna keep the engine i could get alot more hp outta a better engine..
Old Nov 15, 2004 | 05:38 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Yes you could use that kit, however theres much better equipment out there for the $.
Old Nov 15, 2004 | 06:53 PM
TexasLT1's Avatar
Car: '92 RS
Much better ways to get horsepower than that kit. Trust me, I pieced together my own LT4 conversion and in the long run, with my goals, I would have been much better off going another route. I would suggest:
-Ported LT1 heads
-Port matched LT1 intake
-CC306 cam
-stock throttle body bored to 52mm
-used 30# injectors
-1.6 rockers with hardned pushrods/guideplates
-Comp R lifters
-new timing chain
This is just a quick, simple suggestion that will get you more power than an LT4 conversion for the same if not much less money depending on what you get used or new. Check the boards camaroz28.com for some good combos.
Old Nov 15, 2004 | 07:31 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Im with texas, only change I would make, instead of porting the stock heads, I suggest getting the LT4 heads.
Old Nov 15, 2004 | 07:37 PM
pasky's Avatar
Pretty cheap now too...or is it 600 per head? =/:
http://store.summitracing.com/defaul...4+head&x=0&y=0
Old Nov 15, 2004 | 07:44 PM
Incoming's Avatar
Engine: V8 350TPI
i want my car screaming.. it just doesnt have the power it used too... and im gonna only be able to put like 10,000 up for the engine tranny and anything else im gonna need for lots of power...
Old Nov 15, 2004 | 08:09 PM
Incoming's Avatar
Engine: V8 350TPI
what does a average lt1 cost? ive seen some cars around here for like 4,000 with lt1 i should just buy the car and swap it. itd be cheaper then just buying the engine alone cause then i got a parts car... and A/C if i want again lol
Old Nov 15, 2004 | 08:17 PM
pasky's Avatar
For ten grand, I could build one hella fast lt1. I got my LT1 with t56 for 2200 shipped to my door off ebay. Try Cleveland Pick-A-Part in Cleveland (obviously). Thats where I got mine and they are real down to earth guys. Tell them your looking for an LT1 and tranny combo and they may just have one. Then i'd order those lt4 heads, lt4 intake, 1.6 roller rockers, some new valve springs and lockers, the CC306 Cam. SLP 1" 3/4 headers or longtubes, and an aluminum driveshaft. You'll have a 370 rwhp engine for sure and still have plenty of cash left over if you got 10 grand to spend. Hell with that i'd go forced induction.
Old Nov 15, 2004 | 08:34 PM
TexasLT1's Avatar
Car: '92 RS
Yeah the only reason I suggested LT1's was I thought he'd have a lower budget. With the budget you've got, I'd go for some ported LT4's or even AFT LT4's with a ported LT4 intake, 58mm TB, GM847 cam, long tube 1-3/4" headers, and put 400+ to the ground. Might as well go for a 12 bolt with 3.73's or even 4.10's if you get the T-56, run some slicks, and run 11's.
Old Nov 15, 2004 | 10:51 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
I'd suggest a LT1 / T56 pullout.
Add:
Heads / Cam from AI, ported stock LT1 castings.
52MM ported stock TB
SLP 1.75 shortys, reworked with different collectors and a custom Y pipe to a 3.5" catback.
a good replacement clutch and pro 5.0 shifter
4.10 gears in disc 10 bolt with a good posi if its going to stay on street tires.
midge54
Dec 27, 2019 04:14 PM
87iroctheo
Dec 4, 2016 11:47 AM
midge54
Aug 29, 2015 09:51 PM
redmaroz
Aug 16, 2015 11:40 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
