383 Engines
Car: 1986 Camaro
Engine: zz4 350 w/mods
Transmission: 700-R4 W/Shift kit
383 Engines
I have begun yet another motor build. My neighbor is going to have his friend build me a 383 motor. He has some ideas about what parts to use, etc. Its going in an 86 camaro with a 700 R4. I know there are many people out there with 383 motors, and I was wondering if you care to share your parts combos? If you have had them dyno'ed that would be great to show the results. Im looking for around 500hp w/o nitrous. Has anyone acheived that with daily driveability?
Car: 86 camaro z28
Engine: wild 355 chevy sprayed with nos
i dont have a 383 but a 355. i would recomend a powerplus intake. they are pretty expensive but they work really good. i run the pretty tall airgap model. i also run a holly 4150 hp 750 carb. i also put forged pistons and arp bolts in my motor so now i really dont have to worry about my nos blowing stuff up. you also need to think about your compression. if your going to ever add a blower or turbo then you need to go with lower numbers. i run 8.5 to 1 with hopes of adding a blower. i also run a PBM 290 cam and i really like it. and last but not least i run nitrous. i put this motor in an 86 camaro that i drive a few days a week and it does fine. dynoed 510 at the rear w/out nos.
Transmission: 4L80E/4L80E
Re: 383 Engines
From a practical standpoint, it isn't going to happen. If you're a glutton for punishment, however, it'll be fine.
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: Re: 383 Engines
Originally posted by five7kid
Define "daily driveability".
i was one of the glutton for punnishment types when we did this engine.....young and dumb now im older and well a smidge wiser.......
its possible but as five7 stated its all in a matter of what you think can be "daily driven" and what isnt some people think a blown , tubbed , bigblock running 800 hp is "daily driveable" .....some think anything over 400 hp isnt "daily driveable" its all up to what you think is and isnt streetable.
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
My 385 consists of a Cola forged crank, Eagle H beam 6" rods, SRP dished pistons, 9.2:1 CR, AFR 190s ported and polished, Comp Cams blower cam, Comp Cams valvetrain, Hooker LTs, custom y-pipe and 4" exhaust. As for power, I dunno, not enough!!! I built the motor to be blown, I am currently looking for a tranny, iching for a manual, then I will begin saving for the blower. Time is my biggest enemy though. Never enough time to do the big projects any more... Oh well, thats what leave is for...
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
A 230-236 112-114 lsa cam with decent heads and longtubes with the right intake will get you there. My old cam was 230-236 .575 .578 114 lsa and passed emissions and drove fine.
Remember: you can pass emissions with many tricks, you can crutch big cams with more gear and streetability is subjective.
People look at me like I'm crazy when at a stoplight at idle, but I think it's 'streetable'.
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Car: 1989 Iroc Z L98
Re: Re: 383 Engines
It really depends on your definition of streetable.
Car: 1983 firebird S/E
Engine: Built 350
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Its gonna be tough to get a 383 to get 500 at the wheels, at the motor it shouldn't be no problem with a big cam. Remember, the more cubes you got, the more cam you can get away with.
Engine: Built 350
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Spend all your money on the heads, my shortblock is a factory stock as one could get with cast parts and hyperutectics slugs.
For a daily driven substitue the solid roller for a hyd roller and you will have one potent combo. I wish i could drive mine daily, but dont think it's pull my work trialer too well with no hitch LOL. But I'm able to guzzle-literally-pump gas 93 octane and have made many trips down the hwy heading to cruise spots, cruising in parades/car cruises. If I had the benefit of OD or gearvendor I would not think twice about driving it anywhere, but this set-up does like fuel. 20 minutes down the interstate at 65mph 35-3800rpm, about 10 passes down the track with the warm-up ritual since it was very cold that day, then 10 minutes back to a gas station used 10 gallons
Car: 1986 IROC-Z
Engine: 355 ci TPI, 10:1 cr, Isky cam, ported heads, dual exhaust
Transmission: 700R4, ratchetting shifter, 3.23 rear
The reason it works so well is because of the amount of torque these motors are known to produce at low rpms, a lot like a 383 mouse motor (sbc). You can put a little cam in it, but don't go overboard. Same with the compression, and money put into the best heads is money well spent. Last lesson, bigger ISN"T better! Smaller port heads with excellent velocity and flow capability with good swirl characteristics, dual plane manifold, and a smaller carb will usually do better on the street than Humoungo heads, valves, cam, and carb on a huge single plane. Save THAT stuff for the dragstrip! Most folks never exceed 4000 rpm in city driving.
toronto formula
Nov 10, 2015 06:17 AM
