'91 305 TBI to '90 350 TPI
Old Dec 8, 2004 | 11:11 PM
Rally91's Avatar
Car: 1991 RS Camaro T-Tops
Engine: 305 TBI
Hello all!
I am new to the forum and as you can see from the subjecy I am about to swap a 90 firebird TPI 350 into my 91 Camaro 305 TBI.
The good thing is I have a donor car "saved" at a salvage yard. I would like to know what all I will need (besides ECM, fuel pump, and wiring harness) and any other things I need to know before I take this project on.
~Thanks
Old Dec 9, 2004 | 01:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If it attaches to the engine, get it out of the donor car.
What were you thinking with regard to the exhaust system?
Old Dec 9, 2004 | 08:52 PM
Rally91's Avatar
Engine: 305 TBI
As far as exhaust my car has the single pipe crossover to dual outlet muffler (flowmaster) I have been planning to keep the system I have now.
So would you suggest getting the tranny too? And do you know if in 91 the tranny was electronic shift or not? If it isn't we have a police interceptor 700r4 tranny that needs rebuilt that I would use instead
Old Dec 9, 2004 | 09:25 PM
five7kid's Avatar
Your transmission will be fine, although the torque converter in the TPI car might work a little better with the TPI engine.
Your exhaust will be inadequate. Either get the exhaust off of the donor car, or go for aftermarket headers, cat, and exhaust for that application.
3rd gens did not get electronically controlled transmissions. The torque converter lockup is controlled by the ECM, but that's all.
Old Dec 9, 2004 | 09:40 PM
Rally91's Avatar
Engine: 305 TBI
Well I plan on taking the tranny because it has a LOT less miles on it than mine. Why will the exhaust work if I changed everything from the engine back to the cat?
Old Dec 9, 2004 | 09:46 PM
Rally91's Avatar
Engine: 305 TBI
Also I have questions about the ECM. I have heard that I need to change both the chip and controller, is that true? And whereabouts is this located?
Old Dec 10, 2004 | 10:22 AM
Drakar's Avatar
if your flowmaster kit is 2.5" you should change it, but if you picked up the 3" flowmaster kit (measure the I pipe not the tails) you should be fine change back to the cat.
Old Dec 10, 2004 | 11:48 AM
five7kid's Avatar
The ECM is tucked up in the dash above the passenger feet panel. You need to get that, as well as the harness that goes through the kick panel to the fenderwell. Do that, you'll save yourself a bunch of hassle and you won't have to do anything with the chip.
TBI exhaust is horrible from the exhaust ports on the heads all the way to the rear bumper. If any of the exhaust you currently has is for the TBI application, either factory or aftermarket stuff, change it.
Old Dec 11, 2004 | 12:11 AM
Rally91's Avatar
Engine: 305 TBI
good good
I think that just about answers any questions I have for now, if I come up with any more I will be sure to post them. Thanks to both of you
:yourock:
and hopefully after all is said and done there will be more of this
Old Dec 27, 2004 | 06:18 PM
DaGreatKobe's Avatar
Car: '87 Z28, '91 Z28
Engine: 305 carbed, 305 tpi
Transmission: 200TH, 700R4
im like in this same situation. i got a '91 z28 with a blown tpi 305. im looking to replace it with a 350 tpi with my current stock FI setup. i got $4000 to spend on the engine body and paint. ive called around looking for a shop to do everything as far as the engine. i got one guy who said he had an engine from a '93 suburban that he said would work. i was kinda skeptical about that but he said he'll get the engine in there for $1400 including the price of the engine. but anyway i call today and they say they dont do "mods" that they only replace whats in there. anyway back to the drawing board. i need a 350 tpi longblock and installation. anyone know how i should go about this?
do i buy an engine and go the home swap route? or continue the wild goose chase of finding a shop that even has the motor i want in the first place? i live in lancaster, ca and im not gettin anywhere... anyone got any ideas?
Old Dec 28, 2004 | 01:35 AM
Rally91's Avatar
Engine: 305 TBI
Well, I would try calling to find an engine first, but only if you have the tools to do the job. If you do not have the proper tools that make the job easier I would just call some garages.
Good luck finding a 350 TPI they are getting rare, at least here in Missouri.
Old Dec 28, 2004 | 01:55 AM
i found a dismantler that has 2 good running 350 longblocks... and the owner says he knows a guy, that'll do the install for $300-$400. its either that or it looks like im getting stuck with a rebuilt 305 tpi. since i have 2 camaros... i guess i'll just save some money and get a 350 for my '87, which is actually a '82 pace car replica, got lucky with the stock 3.23 posi rear end it came with. so im thinking and engine and tranny for that, edlebrock intake and holley carb and it should move pretty smooth. what do you guys think... or maybe i'll have enough left over for a good 'built' 350 and 700r tranny for my carbed camaro.
Old Jan 4, 2005 | 12:12 PM
thirdgenpurpcam's Avatar
i need a wiring harness and ecm for my 305 tbi and was wondering if u were willing to sell urs if u havent cut it all up.
Old Jan 5, 2005 | 12:07 AM
Rally91's Avatar
Engine: 305 TBI
Well I plan not to sell the harness or the engine, I would much rather keep them. Sorry.
I do have a question for everyone else though... can the harness be adapted over for use on the TPI without major mods, or will that even work at all?
the reason is that the yard I got it from cut the ECM wires and seem to have damaged some small wires that could be fixed, but I would much rather try to use the original harness because it seems to be in much better shape, in fact it has never been touched.
Also the starter off the 305 should work for the 350, right? I know that on other newer GM trucks that sometimes V6 starters were used on 350's.
Old Jul 9, 2005 | 09:35 PM
Rally91's Avatar
Engine: 305 TBI
Hey everybody!
Here real soon I will be starting to replace my 305,
unfortunately the wiring harness for the TPI is damaged very badly. The question is will I be able to adapt the TBI wiring to the TPI very easily? Also I know I have to change the fuel pump, the amount of work to change the in-tank pump is unbelievable, would it work to install an external fuel pump up by the engine itself to increase the pressure for the TPI?
Thanks for any help in advance!
Old Jul 10, 2005 | 11:44 PM
Rally91's Avatar
Engine: 305 TBI
Can anyone help at all? Any help about the fuel pump would be greatly appreciated
Old Jul 11, 2005 | 01:08 PM
five7kid's Avatar
You could do the pump that way, but you'd still need to power the TBI in-tank pump. Powering two pumps may turn out to be more hassle than dropping the tank.
I had a bud who re-pinned a TBI harness to TPI. Spent several weeks doing it. I'd keep looking for a TPI harness, or get one from Painless.
Old Jul 11, 2005 | 10:36 PM
Rally91's Avatar
Engine: 305 TBI
Well, the TPI harness was cut (against my instruction) when it was taken out of the donor car. The wires were cut where the wires come in to the ECM and some of the wires on the lower end were burned. Although the injector and intake wires were unharmed except for the ECM bundle.
Thanks for the insight on the fuel pump. Why is it that you say it might be harder to run both at once?
I'll take a look at Painless, I talked to a GM dealer about a harness.... they only have new harnesses for manual transmissions in stock in my area.
Old Jul 13, 2005 | 12:35 AM
Rally91's Avatar
Engine: 305 TBI
Is there any difference between the automatic and manual wiring harnesses? Because I noticed that Painless doesn't ask anything about the tranmission.
Also I noticed on Painless' FAQ that it says that an engine will not run if transplanted into another car with the original steering column, now I have the entire computer to the new engine but I have my steering column systems original. Will I have to buy a bypass?
Old Jul 13, 2005 | 09:01 AM
five7kid's Avatar
The fuel pump circuit is designed for one pump. If you try to run two, you'll have to make up another circuit like the original for the 2nd pump.
The main difference between auto and manual tranny harnesses is the leg that goes down to the tranny. Beyond that, I can't say about the Painless harness from personal experience, but it sounds like they're talking about the VATS system, which they don't support. I wouldn't think you'd have a problem with that as long as you kept the original system you have now, but I can't say that for sure.
Old Jul 14, 2005 | 03:26 PM
Rally91's Avatar
Engine: 305 TBI
Thank you so much for your help, I owe you a lot!
Old Jul 18, 2005 | 11:13 PM
Cam91z's Avatar
Car: 91 Z28
Engine: 305TPI
Transmission: 5 speed
What part of MO are u from? If u live in KC i might be able to get u a harness. If u havent already gotten one. I know a guy that has a couple thirdgens, not sure if they are tpi cars or not.
Im gona be doin a 350 swap soon too.
Old Jul 22, 2005 | 08:48 PM
Rally91's Avatar
Engine: 305 TBI
Well, I am in jefferson county, basically Hillsboro. And no I haven't been able to find one, we have looked at close to ten salvage yards and have come up with nothing. It seems that TPI is rather rare in my area and in the Ozarks. There are a few more places I can look for a harness, but I still might be interested if you can get me one, just so you know I need one that has a MAF sensor plug and the 9th injector... I ended up with a first gen TPI. That wouldn't be too bad to ship from there. Thanks either way!
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
92purpz28
Aug 11, 2015 02:30 PM
