Engine swap and serpintine setup.
Old Dec 18, 2004 | 09:44 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I'm swapping out a 305 for a 350 (seventies era) on an '85 Camaro. I want to know if I can easily fit a serpintine setup from a later Camaro/Firebird onto this engine. What years would I be able to get parts from. I'm looking for someone familiar with the engine blocks. I"m also using headers so I know there will be some fabrication necassary. And I know about using the reverse water pump.
Old Dec 18, 2004 | 10:16 AM
ljnowell's Avatar
As long as the heads have accessory holes, you are fine. The serpantine setup will bolt up. my brother has an 88 GMC truck that came with a TBI 305. It now has a Carb'd 350 with the same serpantine setup on it.
Old Dec 18, 2004 | 10:43 AM
Scorpner's Avatar
Engine: V6, V8
Thanks!
I didn't think about it but I have Vortec heads. Does that matter?
Old Dec 18, 2004 | 11:11 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
No.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
