high 12s low 13s
Old Dec 21, 2004 | 05:52 PM
unbonyr's Avatar
high 12s low 13s
ok i want to run all motor no spray low 13s maybe even high 12s for under 2500 streetable and hopfully like 20 mpg i know what your thinkin this guy is crazy but ive heard combinations doing it for 2000 and pretty streetable the mpg i dont know but i know it wasnt a killer i would use there combinations but they were all carb motors and i got fuel injected and i would like to keep it that way so if you have some suggestions of what i should do or some combinations please tell me oo yea its an all stock 350 tpi thanks im only 16 so i really apreciate it has 120000 miles on it but not a thing wrong with it and also please not turbo or supercharged suggestions
Old Dec 21, 2004 | 06:43 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Cheapest way is spraying, no way around another cheap way. Steven, who has a stock 91 350 tpi with 4.11 gears and slicks barely ran a 13.9. Only way your getting there is with some headers and the smart way would be to change the intake. You could also slap a carb on but you want good gas milage.
Old Dec 21, 2004 | 07:39 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
For 2500 it will be tight. You can do all the engine work in the world but if you can't get traction, then what good is it. If it were me, I would do suspension and frame work first, that is a good set of SFC, rear end, shocks/struts, tires. Then I would see what it runs and then save more for the engine work. You said it has 120K on it.
Engine work...Cam, heads, intake, exhaust...its gonna get expensive. Look at ebay or other places to find good inexpensive stuff. As for a combo, lots of guys have done very well with the LPE 219 cam/AFR 195 heads/Accel SuperRam intake. Those with a solid 350/383 and about 9.5-10:1 compression ratio will get you in about the neighborhood you would want to be in. Of course then you need computer tuning!!!!
Don't get discouraged, just do one thing at a time. Do in once, do it right the first time...
Old Dec 21, 2004 | 08:06 PM
TexasLT1's Avatar
Car: '92 RS
You're 16, don't get in a hurry. If all you've got is $2500, do suspension and rearend now and get the maximum out of what you have now, then when you have the money build up a better engine. what 92 zzz28 suggested would be a great combo, but good luck getting that built and getting the traction necessary with the money you've got.
db057
Apr 28, 2019 07:45 AM
Linson
Sep 21, 2015 01:08 PM
scottmoyer
Sep 7, 2015 07:06 PM
Stryker412
Sep 7, 2015 09:11 AM
MSgt Luttrell
Sep 5, 2015 11:28 AM
