OMG LS1 for $1,000
Car: 91 Z28
Transmission: 4l60e
OMG LS1 for $1,000
ok guys i might be getting a ls1 engine off a friend for real cheap his bro gave it to him as a gift and he doesnt have a car to harness it so he might sell it to me for $1,000. so on top of that how much would it cost for all the nessecary parts to do the swap?
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
Wow! Nice friend...Or just not un-aware of the value...What kinda miles on it?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You cannot put an exact price on it. There are to many factors to determin how much it will cost. If you buy the parts new it will cost you a fortune. If you find them in a yard it will most likely be cheaper. You need a lot of stuff if all you got was the longblock. Expect an easy couple grand on top of that to remotely get it close.
Guest
Posts: n/a
if it does not have the intake and all, you could save some money and go carb
why in the hell would you want to do that??
an intake you can get from the guys over at LS1tech.com for cheap.. 100$ or less..
that edelbrock carb thing is waaaaaaaay over priced.. not to mention a waste of an LS1
here ya go.. http://www.jegs.com//cgi-bin/ncommer...58&prmenbr=361
$700 for a carb LS1 intake manifold...
Car: 91 Z28
Transmission: 4l60e
well his bro has the whole car that tha motor came out of because he is an emt and he tried to save the girls life that wrecked the car and their parents gave him the car for his efforts so ill have to talk to him and see what was damaged and what is salvageable.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
actually, i am extremely interested in running a carb on an ls1 and it includes way more than just an intake manifold. it includes all the necessaries to have a stand alone ignition sytem on an ls1 as well.
advantages:
weight savings from the all aluminum block
nearly indestructable 6 bolt main caps
blocks can be resleaved if you screw them up(not super cheap but still)
ease of tuning with a holley sitting on top
no expensive computers that can be confusing
cool factor of having a cabed ls1
disadvantages:
poor mileage (like that of any other carbed motor) compared to injection
you still have to pay for all of that conversion stuff ie motor mounts, headers, etc.
no fuel pump bosses, must run an electric (only a disadvantage to some)
that's about all i can think of, advantages far outweigh th disadvantages to me...
advantages:
disadvantages:
Car: 91 Z28
Transmission: 4l60e
hey guys are the conversion parts just parts off of a corvette or do they have to be made for a third gen? cuz i can prob get the conversion parts for free if they are just off a vette
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
I found an LS1 long block for 1000k a week ago here (Quebec)
Thats pretty cheap .. tho to get all the other parts needed.. that will just blow away your budget ..
Technology wise, like mw66nova listed, you win, but the less you get at first, the more you pay later.
Car: 89 Firebird Formula
Engine: Custom Forged 402ci LS2 w/STS Turbo
Transmission: T56 6-speed
Axle/Gears: Moser 9" with 4.11
It's going to depend on what you really want to get out of it.
Are you looking to just get stock LS1 power? Or are you going to mod it? Heads and cam packages alone get expensive real quick. You can spend an easy grand on bolt-ons as well.
You really have to look at the rest of your car though. You are going to want the bigger LS1 f-body brakes all the way around, and an entire new rear end wouldn't hurt. The LS1 is lighter than the older SBC engines, so your suspension geometry is going to need to be adjusted.
Your either going to have to bite the bullet and buy a custom wiring harness, or be capable enough with wiring yourself to get the job done. You'll also need to get new motor mounts and transmission crossmember. Exhaust is going to be another concern. Do you have to deal with emissions? If so, that just added a lot of headaches if you're going to drive it on the streets. (It also makes the Carb'd LS1 option not just a poor performance choice, but an illegal choice - Federal emissions laws prohibit carbing an LS1 for street use).
These are just some of the things necessary. I don't believe you can use many Corvette parts. There are some major differences between Vette and Fbody LS1 engines.
Check out the various threads on LS1 swaps. There is a ton of info out there on them. Average swap is about $8 grand I believe, with only 1/3 of that being the actual LS1 engine. Even if you have the entire drivetrain and want to leave it stock, you're going to spend several thousand on upgrading the rest of your car to make it work properly.
And that last post was correct - the less you do now, the more it will cost you later. Most cost effective to bite the bullet and pretty much do everything you want all at once.
And
And
skinny z
Oct 5, 2015 06:23 PM
