85 vett long block in 88 camaro
Will the 85 long block bolt right in or will i have to have someone fab me some engine mounts. I know I will have to use my oil pan from my 305 what else is different about this vett motor when compared to the camaro. I have a tbi 305 manual 5 tranmission with no work done. I alot just bought a 88 tpi intake complete harness ecm and all. So the full swap will be a 88 camaro 305 tbi to a 88 tpi intake and a 85 vett longblock. any info will help thanks in advance
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
yes it will,how long will it last i could not tell ya but as far as it working as far as mating up and functioning no sweat
Transmission: 4L80E/4L80E
The transmission will work, but the flywheel will not.
The TPI won't bolt directly to the '85 heads because the center two base bolts on each side are at a different angle. You'll either need an '85/'86 f-body or Vette base, or elongate those bolt holes so you can get the bolts into the heads.
You'll need a TPI fuel pump in the tank. The TBI pump won't cut it.
22 lb injectors would be all you'll need. An adjustable fuel pressure regulator is always a good idea.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You also can't use the Corvette's exhaust parts. I know thats typically not associated with a 'long block' but I thought I'd throw that in anyway, just incase.
