Swapping 305 TPI for 350 TPI
Old Feb 6, 2005 | 01:13 PM
90tagta's Avatar
Car: 1990 Trans Am GTA
Transmission: 5-Speed
I've found a 350 TPI block with all of the internals(crankshaft,cam, roller rockers, manifold) for 2,500. It doesn't have any of the externals(manifolds, intake runner, injectors, puleys) Is that a good price? My 305 now as just about 122 xxx miles on her and am wanting more punch when i hit the gas. I know it's a 350 I need because overhauling a 305 would be almost waste of $. Thanks for the help
Old Feb 6, 2005 | 06:50 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
For $2,500 the 350 better be coming with another car. Any more than $300-400, and youre wasting your money. I just sold an L98 long-block for $150.
Old Feb 6, 2005 | 09:42 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Yea, dude that is too much. Does it have heads? For that price, it better have a fresh rebuild, with aftermarket aluminum heads. I just paid $400 for a honed Vortec long block (disassembled) with forged pistons. Granted I think I got a great deal, but hell, for $2500 you should be able to buy a worn-out 350 Iroc.
Old Feb 7, 2005 | 12:15 AM
90tagta's Avatar
I danno if this would change any opinions but this engine is completely new. Exactually zero mileage.
Old Feb 7, 2005 | 12:41 AM
84L69TA's Avatar
Car: 4 Mopars total
Like I said, that "new" motor better come bolted to some sort of an F-body crossmember for $2500.
Old Feb 7, 2005 | 01:10 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
1) GM stock Iron Block (SDPC) 4 bolt main, 1 piece rear main seal =$599
2) 383 Stroker Kit (http://www.speedomotive.com/1piece_s...k_chevy_38.htm)
SILVOLITE HYPEREUTECTIC FLAT TOP PISTONS
COMP. RATIO: 58cc =12.-1, 64cc = 11.-1, 76cc =9.8-1,
TRW HYPEREUTECTIC DISH PISTONS
COMP: RATIO: 58cc =10.5-1, 64cc =9.6-1, 76cc =8.7-1
GM 5.7 RODS - STAGE 1 w/ARP WAVE LOCK BOLTS
NEW! 3.750 STROKE CRANK HI-NODULAR
SEALED POWER CAST RINGS
CLEVITE 77 ROD & MAIN BEARINGS
FREE SHIPPING
+$749
= $1348
Now add your choice of aluminum heads with the $1150 left over and you'll have a hi-po version of what he is offering you.
Note: I don't know anything about that stroker kit, but it's the first one I came across, except that it is a 1-piece rear main 350-383 stroker kit. Just using it as an example.
Fast355
Dec 2, 2016 06:33 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
