how do i get the pan back on
Old Feb 13, 2005 | 12:10 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
how the hell do i get my oil pan back on once its in the car. ive already lifted the front of the engine.
Old Feb 13, 2005 | 09:54 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
how did you get it off in the first place? try reversing the same procedure otherwise you are facockted and you need to pull the engine with a hoist to get it back on.
Old Feb 13, 2005 | 08:05 PM
Chris5k's Avatar
Car: 85 Berlinetta F41
Engine: 355
Transmission: TH700
Axle/Gears: 3.73 posi
I was in the same situation and man thats a pickle... lol.. I took off the oil pump, took off the pan.. but then getting the pan back in position wasnt gonna happen regardless of the oil pump being off or not.... I bent the pan a little bit man.. forced it in there..not exactly the best thing I could suggest but, worked for me
Old Feb 13, 2005 | 08:09 PM
TexasLT1's Avatar
Car: '92 RS
Re: how do i get the pan back on
did you take the pan off before or after the engine was in?
Old Feb 13, 2005 | 09:14 PM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
heres your answer it's not that hard. You can do a search to that how i found the info.
Unbolt the motor mounts.
Jack the motor up (i used the balancer as my lifting point)
**watch out not to cruch the distributor when you tilt it**
Put something in where your mounts bolt on (I put some boards in there)
Let the motor back down.
Rotate the crank til the front counter weight is in the up position.
The pan should go in now.
really tight fit.
I don't remember if i forgot anything so let me say i'm sorry in advanced if i did.
Hope this helps
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
gwade12
Aug 8, 2015 08:17 AM
