LT1 Swap, using FBody A/C Comp.
Old Feb 15, 2005 | 08:31 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
Has anyone come up with a way of using the stock f-body A/C compressor in a 3rd gen? I am in a winterwonderland here.. haha and I am bored, so gonna get A/C working..
I need to acquire the stock LT1 AC Lines so i can see how close things are to the header..
Looking for advice from anyone who has AC running in their 3rd gen LT1 .
I guess 1st off.. am i wasting my time buying a stock hose for LT1 ??
Old Feb 16, 2005 | 01:35 AM
TexasLT1's Avatar
Car: '92 RS
which compressor are you using, the LT1 compressor mounted in the F-body location? If so, stock lines will not work, you'll have to get creative. There was a post not too long ago where some fittings were posted that should allow you to make your own lines.
Old Feb 16, 2005 | 07:42 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
using fbody stuff.. so AC on pass side.. saw that post.. looking like you'd have to be pretty ingenious to make those custom lines.. unless i get the relocation bracket.. which i can't see me doing for the price or the bracket.. was hoping someone had successfully done it so I would have half a clue
Where im at, there isn't many people around who can do custom lines. etc..
So, no sense buying the stock lines then?
Old Feb 16, 2005 | 01:26 PM
TexasLT1's Avatar
Car: '92 RS
I have done it and have working a/c.
No, no sense whatsoever buying stock lines, won't work at all unless you feel like cutting away half the crossmember.
If you don't want to make custom lines, don't try and run a/c. Simple as that. It's going to take some work to get it working. If you get one of the fitting blocks in that post, you can get rubber hoses made with the correct fittings for both sides, then you just have to figure out a way to run them.
Old Feb 16, 2005 | 02:48 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
well, glad i didn't waste money on the stock lines..
is there a special name for the fittings required for the threaded end of that 90deg connector?
Old Feb 19, 2005 | 10:05 AM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Axle/Gears: 7.625, 3.73
You might try this http://www.bowersrodshop.com/
Old Feb 19, 2005 | 02:32 PM
TexasLT1's Avatar
Car: '92 RS
thats nice and all, but for $229 you might as well switch to Vette accessory bracket and move everything over.
Old Feb 19, 2005 | 08:31 PM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Yeh, price is a bit much. As far as I know GM still carries the bracket and support braces for the Vette setup. Also they show up on EBay from time to time in the Brackets, etc section under Engines too. You'll need a Vette crank pulley too and I assume a second belt (right Texas?). (There are a couple of places that have the whole shebang for $750 [Corvette Salvage] and $1000 [Speed and Performance] if you want to get it all.)
You might also get in touch with AV-8R in the HYBRID forum @ http://lt1tech.com for the bracket setup he made to use in his '68 Camaro.
Old Feb 19, 2005 | 09:08 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
to switch to vette.. use same ac comp ?? i thought it didn't..
What do i need to go Vette then?
however i think im gonna get car running again.. then look at the 90deg fitting..
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
Thirim
Aug 9, 2015 06:19 PM
