hp output
Old Feb 23, 2005 | 04:54 PM
chevydude350ho's Avatar
Car: 90 Iroc-Z
Engine: carb'd 350
Transmission: built 700r4/3000 stall
hp output
How much you think i'll make at the crank with this setup. Do you guys think it'd make a decent difference to spend the extra $200 and put on vortecs (I havent gotten the 305 heads yet)?
350 4bolt main bored .030 over
cast flat tops
416 casting heads mild P&P
comp XE274 cam
torkerII
holley 650dp
heddman LTs
Old Feb 23, 2005 | 06:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What valves in the heads?
With 1.94/1.60's, you should be in the 350-375 GFWHP easily.
(Waukesha? I know someone in Waukesha...)
Old Feb 23, 2005 | 11:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Should make some power (I'm terrible at saying how much, so I'm not even gonna try ) but I'd reccomend a different intake. That one isn't bad, but you can do better. I'd suggest a Perf RPM for a combo like that. It will be more street friendly than that single plane, and probably make more power too.
Old Feb 24, 2005 | 02:29 AM
Car: 90 Iroc-Z
Engine: carb'd 350
Im buying the heads completely rebuilt with new seals, guides, stainless 1.94/1.60 valves, retainers, keepers, and LT1 valve springs. The kid im getting them from actually bought them off this board for his formula.
Yeah, thats what everyone has told me. I got the intake for dirt cheap, so ill use it for now until I go to a hotter combo/or the 383 im piecing together. The loss of low end i dont think will bother be, because i had way to much of a traction problem with 882s, and stock 305 tpi, so i dont want to know how bad the tires are going to spin now. Thanks for the suggestions guys.
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
customblackbird
Oct 1, 2015 04:30 PM
6998poncho
Sep 25, 2015 02:56 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
