Those that have swaped to a non ECU controlled carb
Old Feb 23, 2005 | 10:16 PM
84taowner's Avatar
Car: 1984 T/A
Engine: L69
I've decided to switch from the stock q-jet to an Edelbrock 4bbl, so my question is what trottle cable bracket have u guys used to allow you to hook up your throttle cable and the 700R4 kickdown cable? I would also like to use the factory cruise as well but its not a must.
Old Feb 23, 2005 | 11:35 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I have a 5-speed, and soon a 4-speed, so I can't help with the automatic-related questions or cruise questions, but when I did a manifold and carb change (Holley 4160 4bbl, Edelbrock manifold) I just reused the stock throttle cable and bracket. I haven't had any problems with them. Bolted up just like on the stock manifold, and didn't give me a hard time.
Old Feb 24, 2005 | 06:31 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
well, you can go to pep boys and get one of their brakets, you will have to cut it and make it fit for the kickdown part of the braket, i did it, came out good, easy adjustment also.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
383cam
Sep 9, 2015 06:01 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
