eng swap w/ mech clutch
Old Mar 14, 2005 | 10:48 PM
kal's Avatar
kal
Car: 1983 Firebird
Engine: 2.8L-5.0 swap
Transmission: T-5 5 speed
My lil 2.8 finally threw a rod through the oil pan so I'm thinking of putting in a v8. I would like to keep my mechanical clutch because I'll be busy with the new eng and tranny but the problem is the z-bar screws dirrectly into the rear drivers side of the block. Does anyone know what engines will acomidate the z-bar and fit in an 83 firebird and where to get it? Also any suggestions for the swap would be greatly appreciated as I am new the the v8 world.
Old Mar 15, 2005 | 12:31 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Most small blocks have a tapped boss for this cross bar. Trouble you'll have is the 2.8 bellhousing won't fit a V8. The V8 is quite a bit wider than the 2.8 so the Z bar will be too long or won't work there either. Then a 2.8 tranny won't fit up to a V8 engine and housing. Best to find a complete engine and trans unit and go from there I think. Note that the 83 was the only year for a five speed with the rod operated clutch too.
grngryoutmyway
Oct 18, 2016 05:48 PM
88rscamar0
Sep 23, 2015 09:08 PM
Denricci22
Sep 18, 2015 09:02 AM
19irocz85
Aug 30, 2015 10:03 PM
rsrmoore
Aug 7, 2015 08:44 PM
