flexplate question
Old Mar 31, 2005 | 08:15 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
flexplate question
I'm in the process of rebuilding a '77 350 to go in place of my 305 HO in my 84 Trans Am. I am going to buy a new balancer and flexplate and have everything balanced for the 350. My question is should I buy the 153 tooth, or 164 tooth flywheel? Does the 350 block have a different bolt pattern for the starter? Which starter should I buy, one for a 77 chevy, and will it have clearance problems or are all starters the same size/shape? Any thing else I should know? Thanks for any help.
Old Apr 1, 2005 | 10:14 PM
Robert91RS's Avatar
Car: 1991 Camaro RS
Engine: 350 TBI .60 over w/ forged pistons,
Transmission: 700-R4 custom built
I believe that for your transmission, you want a 153 flexplate. In my experience, if you cant go with a high torque gear reduction (aka mini) starter, use one for the car as long as it bolts to the block. Hope that helps.
Old Apr 2, 2005 | 12:26 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
You can reuse the flexplate off of your 305 along with the starter. Just make sure the starter will bolt to the new engine. If not, have a machine shop drill and tap the hole you need for your original starter.
Old Apr 2, 2005 | 03:19 PM
84 t/a 5.0's Avatar
Can I just buy a 153 tooth flexplate, and a starter for a 77 chevy? or will the starter not work with the 153 tooth flexplate, or not clear other parts?
Old Apr 2, 2005 | 03:40 PM
Lo-tec's Avatar
You want to use a starter and flywheel for the car the engine is going into, not the one it came out of. You can buy another 153 tooth flexplate, but be sure and get the starter for your car.
Old Apr 2, 2005 | 04:32 PM
84 t/a 5.0's Avatar
so I pretty much have to get the block drilled and tapped then? thanks for the info
Old Apr 2, 2005 | 05:15 PM
Lo-tec's Avatar
Read through this post, or just look at the pix posted by RB83L69:
https://www.thirdgen.org/techbb2/sho...hreadid=287166
If it has all three holes you're good, if not get it drilled and tapped at a machine shop while it's out of the car.
Old Apr 2, 2005 | 06:22 PM
84 t/a 5.0's Avatar
My 350 block looks like the one in the pic, but in that post it says the hole has to be where the lines intersect, so I take it I have to have the block drilled?
Old Apr 2, 2005 | 07:39 PM
Lo-tec's Avatar
Correct
Old Apr 2, 2005 | 07:50 PM
84 t/a 5.0's Avatar
thanks for the help
Old Apr 5, 2005 | 10:58 PM
robby_0351's Avatar
Car: 83 Trans Am
For the learning impaired-I am hearing that you cannot use a 168 tooth flexplate with a 700r4. And if not why not?
I just looked up this http://www.bowtieoverdrives.com/cata...SUBCAT&CATID=R
It is a catalog item for a 168 tooth flexplate for a 700r4. What am I missing here?
Old Apr 5, 2005 | 11:17 PM
Robert91RS's Avatar
Car: 1991 Camaro RS
It should be too large in diameter, meant for the 400, 4l80e, etc.
Old Apr 6, 2005 | 09:42 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
A 168-tooth flexplate fits in the TH700 bellhousing. The only issues are whether the starter required for such a flexplate will mount to the engine, and whether the starter will interfere with 3rd gen exhaust. The solution typically is to use a mini starter when using a 168-tooth flexplate or flywheel.
Old Apr 6, 2005 | 02:05 PM
Robert91RS's Avatar
Car: 1991 Camaro RS
Well there you go, I learn something everyday.
Old Apr 13, 2005 | 11:47 AM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
I can speak from experience, that five7kid is correct. I'm having a different issue, but when that gets fixed, it'll function correctly. Here's what I'm dealing with.
https://www.thirdgen.org/techbb2/sho...hreadid=287013
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
gwade12
Aug 8, 2015 08:17 AM
Leggman1
Aug 6, 2015 04:15 AM
