lt1 motor mounts
Car: 91 RS (Black, T-top)
Engine: 5.0
Transmission: 5-speed
lt1 motor mounts
I know the motor mount have to be modified for a/c, but where do I get the motor mounts that are already designed for the swap? thanks
It's good for one guy to say, "No such thing" if he/she already knows the answer. But, that doesn't actually HELP the person that asked the QUESTION.
Basically, you use stock Thirdgen SBC mounts, and if you want to keep a/c, you notch the K Member to clearance the compressor.
Engine: 5.0
I was asking, because I read somewhere, about some "carquest" or something like that, mounts that were designed for lt1 swapped 3rd gens. or maybe i smoked too much that night...
Car: 91 Firebird
Engine: 6.0
You basically read the line about going to carquest to get the ac line for the LT1 swap.
All I did was use a cutoff wheel and notched the mount. Took all of about 3 mins.
I'll try to upload some pics on thursday or so...... its not that bad
you still have to notch your crossmember, but its not much. Some have pounded it in with a hammer, I chose to cut it out. Same cut off wheel, maybe 10 mins of slow cutting (and the notch was still longer than it had to be)
hope that helps
-jason
hope that helps
-jason
Yes, the CarQuest line was about the A/C fittings, not the motor mounts.
As far as the tubular cross-member, not sure if anyone has completed the swap to know if it clears. I would think it would due to the angles, but I don't know where the main tube is at in relation to the compressor.
ambainb
Apr 25, 2016 09:21 PM
NBrehm
Aug 5, 2015 07:57 PM
