LS1 Swap- AC line?!?!?!
Old Apr 16, 2005 | 04:04 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
I'm getting close to dropping my LS1 in my car and today I was cutting/modifying my spare stock k-member so the 4th gen LS1 AC compressor would work. My only problem now is trying to figure out what AC lines everyone is using to hook it up. I was looking at my stock ones still in the car and looking at the stock 4th gen ones and I'm not sure either one will work. Can anyone help? Anyone have pics? PLEASE let me know.
Thanks!
-Jeremy
Old Apr 17, 2005 | 07:59 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I used the 4th gen lines so that it would clear the crossmember (providing you notched it out enough) and clear the exhaust, however I have NOT changed the ends on it yet, so its not hooked up to the condensor/accumulator yet.
Old Apr 17, 2005 | 11:51 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
So is that what everyone is doing or what? I think I'd have to remove alot more material on my k-member to do that
Old Apr 18, 2005 | 04:54 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I tried "massaging" the stock line to clear the exhuast manifold and I was almost there before it kinked. Thats when I decided to see if the 4th gen line would fit. If you can find a line that will clear everything, different thickness seals are available to make it more adaptable to the compressor.
Old Apr 18, 2005 | 06:13 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Thanks! Anyone else??
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
dbrochard
Sep 19, 2015 08:13 PM
R13_Braz
Sep 18, 2015 05:00 PM
timonator
Sep 17, 2015 06:57 PM
TBRays98
Sep 6, 2015 05:05 PM
