No Start
Old Apr 19, 2005 | 03:38 PM
ssean92's Avatar
Car: sold
No Start
ok guys sorry for the question and im sure it has been asked before but i couldnt find it in a search. Ok here is what i got, I got my lt1 swap completed had the car running with a vats bypass module, well i found a guy on the internet that does computer reprograms so i sent it to him to get the egr/smog pump deleted and vats turned offf and so fuel configureations stuff done. well i hook up the computer after i get it back and now it will crank but no fuel pump???????????? i emaild the guy and he says that i need some kind of hardware for this to work . that is that i need something for the vats that is. i have never heard of this i figured that i wouldnt need anything once the vats was shut off. oh yeah before anyone askes the car ran godd just had the service engine light. and i also have cked the fuel pump and the relay they both are good. hope someone can help me out. sean
Old Apr 19, 2005 | 05:16 PM
ssean92's Avatar
Car: sold
come on everyone no one
Old Apr 19, 2005 | 05:54 PM
kevinc's Avatar
Car: 1982 Z28
Re: No Start
First, calm down. Wasn't even 2 hrs between your initial post and the nagging followup.
Second, plug your VATS bypass module back in and re-test.
Third, find out what "some kind of hardware for this to work" means and post it here. Need the specifics that he told you.
Old Apr 19, 2005 | 08:01 PM
ssean92's Avatar
Car: sold
first off i wasnt getting out of shape second i told you he said he didnt know what hardware i needed he was told that some thing was needed. and i did reconect the vats module and still nothing. I saw how many oeople looked at it and there was no reply sory if you took it that way
Old Apr 19, 2005 | 08:51 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
I thought that Vats turned the injectors off, not the fuel pump? No? LT1's may be different.
Have you checked all fuses and such? Have you tried hot wiring the fuel pump?
Old Apr 19, 2005 | 09:17 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
One thing I've found out is my fuel pump relay wire isn't giving enough power to close the relay and enable the fuel pump, I'm taking my PCM back to have it checked and make sure that the VATS is turned off.
Do you get the prime when you turn the key on? If not, more than likely VATS is still enabled in the PCM.
4th gen cars VATS turns the fuel pump off instead of the injectors. You can crank the car all day but it ain't gonna start.
Old Apr 20, 2005 | 05:08 AM
kevinc's Avatar
Car: 1982 Z28
You sure that's the "expert" you want working on your PCM?
You didn't indicate that in your post...in that case it's time to whip out your scanner and check for codes, then RPM indication during cranking.
It's like a car wreck on the highway, lots of people look but doesn't mean they're about to get out and help
Old Apr 20, 2005 | 08:01 AM
ssean92's Avatar
Car: sold
the one thing on the vats is, when i got the computer hooked up (forgot to hook up the vats) i got the prime. then nothing. I hooked up the bypass module it ran. so i cant see how the vats is doing that when i was getting the prime. now i am not even getting that. but i do agree with you on getting the codes. the cat will run with the fuel pump hot wired and the relay is good. so i quess the computer is messed up in some way. I need to send it back to him to get it redone. inless someone has a idea what is wrong. thanks for your replies
Old Apr 20, 2005 | 10:11 AM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
Just run your fuel pump off a manual switch if its too much trouble.
Old Apr 20, 2005 | 10:21 AM
kevinc's Avatar
Car: 1982 Z28
And when you wreck, be sure you're conscious and turn it off before the car burns up w/ you in it.
I like the PCM managing the fuel pump personally, good safety feature.
Old Apr 20, 2005 | 10:55 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
So you did check to see if the PCM was sending 12V to the Fuel pump relay? This really dosent make sense, if the Vats is still in there, why would act up after you reinstalled the Vats bypass module. Surely theres no way to screw up the programing to where it totally shuts off the fuel pump circuit? Send it back to him I guess, or find someone else to look at it.
Old Apr 20, 2005 | 11:24 AM
SweetRide45's Avatar
You shouldn't even need the Bypass module if you disable vats in the pcm. I say get yourself a laptop, interface cable, software, and diagnose it yourself
Old Apr 20, 2005 | 12:42 PM
Transmission: th350
Fine wire it up manually, but wire a ford interia switch in series. Problem solved.
Old Apr 20, 2005 | 05:44 PM
ssean92's Avatar
Car: sold
i cant believe that some one said to run a manual switch on a stock pump???????????? thanks for the advise but no thanks. I am and sending it back to the guy, after talking to him he had flashed the computer with it being a manual tranny. seeing how i told him Im not using the tranny harness, i have a 700r4, he seems to think it has something to do with that. so he is going to put it back to a auto and reconfigure it with just the power tune and the egr/ smog pump delete and return everything else to factory. I think that will repair the problem seeing how the harness is for a auto, i think the computer is confused. I will let you all know what happens after i get it back.
and on the get a interface cable i have one in the harness its just money got tight and didnt have the money for the 300.00 program and the 1000.00 laptop. so i went that route to get the car running. thanks for the replies. sean
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
