speartech harness
Old Apr 22, 2005 | 12:33 AM
Kandied91z's Avatar
speartech harness
anyone running one of these for their ls1 swap.
i was looking into one for mine as the $450 for the rework sounded reasonable with limited time. after i added an extra $350 for a new one since i needed an extension to put the computer in the factory location i also needed another $300 for them to adapt the new custom speartech harness to part of my 92 dash harness so that my factory guages would work.
what looked to be a simple $450 rewiring eneded up right around $1,100 to use the motor with the factory guages and have the computer in the stock location.
just wondering what those of you who have used speartech ended up choosing for a route? as i thought you send in your factory ls1 harness, spend the $450 to rework it and call it a day but that isn't the case.. granted the $300 is because i don't want the computer under the hood but $1,100 and i have to give them several parts of my harness seems a bit odd as the wiring is starting to cost me more then the complete drivetrain itself.
Old Apr 22, 2005 | 07:29 PM
1bdbrd's Avatar
Car: 1991 Trans Am
i would really like some info on this as well. i havent looked specifically for info about the harness, but i havent found much about it. i wonder if it makes it a pretty much "bolt-in" wiring job or if there is still custom work that has to be done? and how easily would this connect to something like autometer gauges?
Old Apr 22, 2005 | 11:05 PM
Kandied91z's Avatar
anything aftermarket isn't plug in play. when you spend $1,100 for a reworked ls1 harness it had better be plug n play.
what your looking for would be around $450 just to rework a few of the ends to adapt to our stock equipment and then you would have to personally find out how to tie in the autometer guages. another $300 and part of your factory thirdgen harness and it would work plug and play with factory guages or at least be labeled for aftermarket.
$300 more from them will get you their brand new custom ls1 harness which is extended. they will not extend factory ls1 harnesses.
that's speartech though, there are other options, cheaper options out there.. especially if you aren't going to use the factory guages.
Old Apr 26, 2005 | 11:11 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
I tried contacting Speartech and got no response. 1100 bucks for wiring is way too high priced for me. I'll go carbed before I spend that kind of dough on wiring. Their prices seem to be climbing rapidly now that their name is out there. Turn around time is months as of now too from what I have read on other boards. 1100 bucks plug and play? Damn well better look sweet as cherry pie for that kind of dough too.
Old Apr 26, 2005 | 01:08 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
If you get the factory harness with the engine, try LT1350 he modifies LT1 and LS1 harness if you don't want to attempt to wire the car yourself. His prices are very reasonable.
Old Apr 26, 2005 | 01:37 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
his stuff is very high quality and plug and pray...
but for a 3rdgen, where its almost a bolt in, i cant justify the cost.
do some searching under my name on ls1tech.com..... you'll find that while the PCM doesnt reach the "stock location" of being vertical under the dash, it still fits under the dash NEAR the stock location with the stock harness.
Old Apr 26, 2005 | 01:45 PM
Kandied91z's Avatar
do you have to cut a makeshift hole in the firewall to fit that location? i don't care if i fit it in the fender well i just don't want the ecm anywhere in the engine bay you know.
Old Apr 26, 2005 | 01:47 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
cool Thanks Dude. I haven't had enough time yet to tackle the wiring so I am getting antsy. The car is in pieces blocking up my shop and I gotta get it done soon.
Old Apr 26, 2005 | 02:12 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
from what i read online:
hawks thirdgen sticks it in a existing hole.
from what i did:
i made a clean 2" hole with a holesaw, stuck the harness thru, put a grommet on it, and it looks factory. the harness wire bundle itself is roughly 1.800" so its just a "rubber band" looking grommet to make the edge look clean and seal it all.
i know what you mean about it being in the engine bay though.. i tried it everywhere.. it jsut doesnt work.. it needs to be underdash for that clean look.
Old Apr 26, 2005 | 02:15 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Got pics of the hole location by chance? It would save me the hassle of in and out one more time
Old Apr 26, 2005 | 02:26 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
you do have a reasonably large range to work in...
i dont have any really good pics of that area... i kinda wish i did since im asked about it frequently... someday when i get a camera, some time, and i remember, i'll take some more.
heres the best i have... this is before its done (obviously) but it'll show you the general area you have to work in.
it looks alot neater now.. lol.
Old Apr 26, 2005 | 02:48 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Thanks Dude. No ac for you? I'm running it. Hope that dont give me grief.
Old Apr 26, 2005 | 03:01 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
gotta have my AC..... aftermarket AC that is.
vintage air... havent installed it yet.
i couldnt stand how large the factory AC box was...
Old Apr 26, 2005 | 03:03 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
lol yeah man its friggin huge. I'm gonna work around it somehow. Ladies gotta have the Ac. Messes up there hair and all with the windows down y'know lol
Old Apr 26, 2005 | 03:17 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
i woudlnt know.
the tops always down, and if they dont like it, too bad.
Old Jul 11, 2005 | 01:19 PM
Kandied91z's Avatar
well i ended up trying howell engineering here in michiganl $850 for a 60' pigtail setup, dual fans and a few other little trick things i added and it works great. direct plug in for all but the tach which is half of what it originally was. should be able to figure that out soon though. thanks for the suggestions.
Old Jul 11, 2005 | 01:46 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WD1V
Old Jul 12, 2005 | 10:05 PM
silverta8702's Avatar
cheap ls1 harness conversion
hey guys i have an 87 ta with an ls1 i can get your harness redy to go a lot cheaper than 1100 i did it myself andit faily easy email me at silverta8702@yahoo.com
Old Jul 13, 2005 | 12:18 AM
5.0Camaro's Avatar
Car: 1991 camaro Z28
Hey kandied91z, where you located in MI. I'm in saint clair shores right now(9 mile and jefferson), if you want to see mine your welcome to. Its been done for about 2 weeks and i just drove it from cali to MI (averaged 30 mpg ). I got my harness reworked from speartech, and cut the hole in the firewall. I leave tomorrow for spain but i'll be back in a week, so just pm me if you want to hook up sometime.
Justin
KO1
16
Oct 15, 2015 05:00 PM
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
z28joe2
Sep 28, 2015 05:54 PM
Eric-86sc
Sep 28, 2015 11:37 AM
