pontiac v8 swap questions
Old Apr 23, 2005 | 02:04 AM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
so im really considering this into my 92 bird. i wanted to know what my options are as far as motor mounts and headers/exhaust manifolds..
i was also wondering what some problems people have run into doing this swap.
oh, and any pictures of poncho powered thirdgens would be of much help!! i need ideas....
thanks in advance.
Old Apr 23, 2005 | 10:16 AM
LT1guy's Avatar
Car: 1987 Trans Am
See the sticky...its all there.
Old Apr 23, 2005 | 11:12 AM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
ive read through that, i was looking for a bit more specific info.
what casting number for the exhaust manifolds fit with the least amount of hacking? does the oil pan fit with the stock k-member? is there any problems with the distributor and the firewall?
Old Apr 24, 2005 | 07:52 PM
swimster's Avatar
Car: 99 Subaru, 92 GMC Van, 95 Bonnie
Engine: LOTS of them
Transmission: LOTS of those too.
most of the stock pontiac manifolds fit well, the stock pan fits fine, and there's tons of room between the firewall and the distributor. there's a bunch of pics on that stickey from another link I posted. This swap, seems to be ALOT more popular than previously thought on this board, so.. there's plenty of things out there to make it work on the cheap. I'm doing the same swap.
Old Apr 24, 2005 | 09:50 PM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
what are you doing for the cooling system and your exhaust? just wondering.
Old Apr 24, 2005 | 09:53 PM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
oh and i picked up a '66 389 tripower today. and a 79 th-400. the engine was rebuilt with a bunch of good ****. it should be in the 450-500hp range. i have to figure somthing out about my intake and carb setup tho. i think it would be badass to put the tripower on, but the damn thing is SO F'ing heavy.
im also working on some pics of the whole swap.
Old Apr 25, 2005 | 05:30 AM
swimster's Avatar
You sould really read thru the swap sticky. all these questions are in there. but I use the stock 3rd gen radiator for now, the exhaust needs to be custom fab'd which is also in the stiky with a BUNCH of pics. and with that kind of HP and the sheer torque, oyou're definitly going to be breaking the rear end and twisting the car quite a bit. you'll need sub frame connectors and such too.
Hotrodboba400
Dec 10, 2019 07:07 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
usafirebird
Sep 29, 2015 11:58 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
