need a starter wire diagram
Old May 1, 2005 | 10:11 PM
kdubdizzle's Avatar
Car: 88 camaro
Engine: 305 t.b.i
does anyone have a diagram or could tell me how to hook my starter up correctly. i swapped my v6 to a 305 tbi and i think i might have wired my starter wrong because i turn my key and i get nothing out of it, no noise. it does not even make a sound when i turn the key. i know my starter is good. maybe it's not the starter. i don't really know. help please!
Old May 2, 2005 | 12:42 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
This is for an 85 LG4, but they're all somewhat similar:
<img src="http://www.geocities.com/vtcamaro/Pictures/wiring-diagrams/pg127.jpg">
Old May 15, 2005 | 05:20 PM
Franchise's Avatar
ME TOO!!
Hey,
I am having the same problem. I have it all wired up and nothing from the cranking side.
I am swapping a 350 into my V6, it is a 1991 Firebird.
1))) I have seen that diagram and I have wired it up as 2 fusible red wires to the battery post.....??? is this right.
Also, 2))) Trying to fully decipher that diagram, now I am wondering if I need a purple? wire attached to the S post? On the diagram I see 2 starter solenoids....or am I confusing myself.
3))))soo, I have a stock v6 wiring harness....how do you wire it, since my starter now has 3 posts.....Batt, S, and R.
Any info greatly appreciated!!
Thanks guys,
Franchise
Old May 15, 2005 | 05:24 PM
TexasLT1's Avatar
Car: '92 RS
whoa, in color. where did you find that? all the ones I've ever seen are black and white.
Old May 15, 2005 | 06:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They're in color in the factory service manuals, which someone has conveniently scanned and posted in the tech articles.
Old May 15, 2005 | 06:45 PM
TexasLT1's Avatar
Car: '92 RS
outstanding
Old May 15, 2005 | 07:01 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Here is the starter circuit for the 91 Firebird, should be all engines
Old May 16, 2005 | 07:29 PM
Franchise's Avatar
Klortho,
Great Diagram! I have the factory service manual...but it is hard to read...like the one posted previously. Which is that? Where did you get it from?
Anyway, What are the numbers next to
the color codes (ie, 3 ppl)?
This purple wire that needs to go to the starter, is it a thicker gauge than the rest of the wires in the harness....????.....is it thick like the red wires for the starter/positive?????
Thanks for the great help!!!
Old May 18, 2005 | 09:17 PM
dubs420's Avatar
can i get this for a 92 rs 305v8 i swaped to 350 crate i hade to use a push button and a key
Old May 18, 2005 | 09:48 PM
TexasLT1's Avatar
Car: '92 RS
check the Technical Articles on the Thirdgen.org main page, they are all posted there. not to mention its going to be almost identical.
Old May 24, 2005 | 03:54 PM
kdubdizzle's Avatar
Car: 88 camaro
Engine: 305 t.b.i
I'M AN IDIOT! I FOUND MY PROBLEM, MY GROUND WAS ON THE WRONG PEG ON MY STARTER, IT WAS WIRED TO THE ONE ON THE LEFT AS YOUR LOOKING AT THEM. THE PEG IS SUPPOSED TO BE THE ONE ON THE LEFT. I'M STUPID, MAYBE THAT COULD BE YOUR PROBLEM.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
Accerrito22
Aug 23, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
