350 swap on 92 RS
Car: 1992 camaro RS
Engine: 305 tbi
350 swap on 92 RS
ok everyone here's what im doing......
im buy a '92 350 tpi longblock from www.rebuilt-auto-engines.com heres the link------
http://www.rebuilt-auto-engines.com/...53105622444.3a
heres my questions about this swap...
Will my starter bolt up to this motor?
Will my accesories bolt up (power steering and all that stuff....im pretty sure it will but just making sure)?
the motor is a 2 peice rear main seal...do i need a diff. flywheel also? ( i have the L03 tbi)
im keeing the tbi setup...and i think i need 350 injectors, 350 esc module...is there anything else? i have a few more questions/comments...but ill save them for after i get this stuff cleared up...
thanks a lot guys.
thanks a lot guys.
Car: 1992 camaro RS
Engine: 305 tbi
thanks a lot.
is the esc module and the 350 injectors all ill need for the new motor. also....whatsize injectors...i was thinking 55 lb.
i want to make around 300 horsepower at the wheels with this motor...will an lt1 cam be enough to support this or should i get a different one.
just a few more questions....not specifically engine swap though...but here goes.... does the 454 tbi have 2 inch bores and can the edelbrock tbi manifold be bored out to accept 2 inch bores (i beleive it can).
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by tealcamaroRS199
thanks a lot.
thanks a lot.
