Finally putting my new motor in
Old May 9, 2005 | 01:10 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
Well after 2 yrs my camaro will run again...soon...i only have one problem at the moment. When i removed everything i broke off both of the drivers side tranny crossmember bolts nearly flush with the subframe. I may be able to get on it with vice grips but it is rusted in there very well and i dont want to ruin it. Is there is a easier way to get this out or does anybody have more suggestions?
Old May 9, 2005 | 01:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Start soaking them with penetrating fluid (PB Blaster seems to be the Board fav) as soon as possible. Get some in from the back side if possible. Drill for easy out, drill & tap for next size up if that doesn't work. Last resort - knock the nuts out (not that hard to do), stick some regular nuts up in there when you mount the crossmember.
jhawkeye
May 25, 2022 06:33 PM
Polo Z03
Sep 10, 2015 06:43 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
slade5612
Aug 11, 2015 07:19 PM
Leggman1
Aug 6, 2015 04:15 AM
