86 Motor Swap to my 91 Motor??
Old May 9, 2005 | 04:25 PM
BaggedDropTop's Avatar
Car: 1991 Z-28 Covertible
Engine: Stock
Transmission: 5-spd
Hey guys just needed alittle advice being that im not much of a motor person. I have done all my visual stuff to my car so now i am moving on to the motor. Someone i know had an 86 Iroc motor that was rebuilt and never installed. They put a different cam in it and center bolt heads on it, which i know my TPI needs. I am getting it for 500 bucks without the intake so i basically planned on putting my TPI from my 305 onto the 350. Im just wondering what would be any problems if any using the 86 motor. The only thing i know is that it has a flat cam and mine has a roller. I am also getting the 21lb 350 injectors as well. Any adive on this would be greatly appreciated. Thanks
Old May 9, 2005 | 05:23 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Its illegal to put an older engine in your car (but unless you have to get it inspected, and such, ignore that one)
The flywheel is diffrent , the '91 engine had a 1 pc FW, this one has a 2 pc.
Im not 100% sure on that, others might shim in.
Good luck
Old May 9, 2005 | 06:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
'86 has one-piece rear main seal.
However, '86 IROC 350 doesn't add up. Make sure you're not getting a 305.
Old May 10, 2005 | 08:10 PM
Engine: Stock
Transmission: 5-spd
Yeah im not exactly possitive the year, i just know it was an older 80's motor. But it is forsure an L98 motor. It came out of one car and was put into a 88 GTA. Then before they got the intake on they ended up starting a different motor. So they are going to pull the motor out of the GTA and then i am going to get it. I just know it was rebuilt and has an engine works cam package in it as well as center bolt heads. Im getting it from a girl that works at THIRDGEN RESOURCE in Charlotte, i just live 2 hours from their. her boyfriend bought the parts and did the rebuilt himself because he is a service tech for a lincoln dealer. Their for he knows his stuff pretty well. I was just making sure i was gonna be good. I mean hell im gettin the motor for 500 bucks.
Old May 11, 2005 | 08:49 AM
five7kid's Avatar
Check the casting number of the block before any money changes hands. Same for the heads. It sounds like it has a "history", and a trail that is not simple to follow. You could be getting ahold of a 305, as nothing you've said yet limits it to being a 350. And, I wouldn't necessarily trust a Lincoln dealer tech to know the differences between a "good" SBC and a dog.
One of the best reasons for "before they got the intake on they ended up starting a different motor" is they discovered it was really a 305.
Old May 11, 2005 | 02:08 PM
Engine: Stock
Transmission: 5-spd
yeah, ur right. I am going to talk to the guy today about the motor and i know they have all the receipts from the rebuilt that was done so im gonna be sure to pay attention to that before i go any further. thanks for the advise.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
