Lt4 Swap my fuel gauge and starter
Old May 20, 2005 | 09:42 PM
Deaclen's Avatar
Car: 91 camaro Z28
Engine: LT4 Intake & Heads bottom end 94
Well i almost have my swap completed guys but my gas gauge will not work and neither will my fule pump ick on when i turn the key.... Now i have everything hooked up except for the electric air pump and the starter. but i would think i would still see the gas gauge and the fule pump work so i can only think that the wiring is not done properly. I had LT1350.com do the graph for me for the wiring harness. No i think the VATS disabler they did not install so what i am going to do is take the vin number for the PCM and take it up to the dealership and have them make a key with the vats reading it needs so my regular key will work since the disabler is not working or not installed but still need help with the gauge and the fuel pump let me know and i think if hte vats is wrong then the fuel pump won't come on let me know guys any input would be great thanks
Old May 20, 2005 | 10:43 PM
Deaclen's Avatar
Car: 91 camaro Z28
umm nevermind guys i had an idea and went out and tried and now it works i am an idiot i forgot to hook up a ground wire my bad guys
Old May 20, 2005 | 10:57 PM
TexasLT1's Avatar
Car: '92 RS
haha, its always the little things. glad to hear you figured it out though. let us know how it runs. good choice with the LT4 even if I am a little biased
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
