Braided Fuel Lines from stock tank?
Old May 22, 2005 | 09:02 PM
AC's Avatar
AC
Car: Used to drive a camaro
I have a 91 1LE that I've done some major updated/modifications to. I don't know where else this thread should have gone. I want to know if it's possible to run braided fuel lines from the stock 1LE tank to my fuel rails? The reason being, I'm fabbin a true dual exhaust to run down both sides of my driveshaft tunnel and wanted to run braided fuel line above the driveshaft getting away from the exhaust heat. Ideas / comments?
Old May 22, 2005 | 09:11 PM
TexasLT1's Avatar
Car: '92 RS
you could but you'd have to have -AN fittings welded/braized onto the hard fuel lines coming from the pickup unless you sumped it and ran an external pump
Old May 22, 2005 | 09:16 PM
AC's Avatar
AC
Texas, thanks for the info. I have to take the pump/pickup out next week anyways to drop in the new Walbro. This would be a good time to get the fittings on then. The lines are metal or aluminum? I can't tell by looking at them.
Old May 22, 2005 | 09:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't have to weld or braze, you could flare the stock lines with tube nuts.
Old May 22, 2005 | 10:08 PM
TexasLT1's Avatar
Car: '92 RS
hmm, good call, totally forgot about that.
long day
Old May 23, 2005 | 10:02 AM
AC's Avatar
AC
I thought I read that flares/tube nuts couldn't withstand TPI fuel pressure? Or is that compression fittings only? FYI, I'm running a 14lb supercharger with a Walbro 255 pump. I'm estimating my FP will be between 44-80psi.
Old May 25, 2005 | 01:08 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I am in the process of doing this. I will try and post some pics. But I am running a -08 feed with a -06 return and I got rid of my canister line. I just bought some weld on an fittings and tiged them on the fuel sender.
Old May 25, 2005 | 10:29 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
I am running compression fittings from the stock hardlines on my setup. I don't see them leaking or blowing out, once on they are pretty firm and can't be moved by hand no matter how hard I try. If you tried mechanically to move them you would most likely twist the line or break it before the fitting came off. I run a walbro in tank 255lph at 45 psi idle with 30lb svo injectors.
The 3/8ths and 5/16th fittings can be had from Jegs, 3/8 is always in stock the 5/16 you need to find the P/N at the earls website and punch it in the jegs search block, it is special order.
EDIT: I stand corrected on the special order part, I ordered up some earls 5/16th ones three days ago and they just arrived today, so apparently in stock now, part number on the invoice 0361165056.
Old May 25, 2005 | 04:34 PM
AC's Avatar
AC
This is great info guys. Thanx. Post pics when you can. I plan on doing the same and showing how I routed the fuel lines above my driveshaft.
Old May 26, 2005 | 02:36 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
don't the orginal fuel sender lines have saginaw fittings already? you're 91 should have 2 already on there. It should be a simple matter of using the same adapter from the fuel lines on the fuel rails:saginaw to -6 or -8. You would have one each of the 14mm and 16mm connections, 2 at the tank, and 2 at the fuel rail hard lines. the only line that is more difficult is the fuel vapor return from the canister. I don't beleive you should have to cut or flare or use any other type of connection other than the saginaw to -6, used for either TBI or TPI.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
