pulling the motor
Old May 27, 2005 | 09:04 AM
kamaroirock's Avatar
Car: 02 z28, 03 wrangler sport
Engine: ls1, 4.0L
Transmission: t56, 4speed auto
pulling the motor
im pulling the motor soon but im not sure where i can pick it up from since there arnt any accessories or heads on it how can i get it out when its just a block?
Old May 27, 2005 | 10:27 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Head bolts through a chain into head bolt holes.
Old May 28, 2005 | 08:53 PM
Engine: ls1, 4.0L
and that shouldnt bend the the bolts any right?
Old May 28, 2005 | 09:22 PM
AJT86's Avatar
Car: 87 Buick Grand National
Engine: 3.8 SFI Intercooled Turbo
Transmission: 200R4 3000 Stall
they wont bend ive done that plenty of times
Old May 29, 2005 | 10:48 AM
five7kid's Avatar
Use the short head bolts.
They're tough. Even the long ones shouldn't bend, but use the short ones just to lessen the possibility.
Old Jun 2, 2005 | 08:43 PM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
Engine Pull w/No Heads
kamaroirock,
Just pulled ours a week or two ago. Used the tranny mount bolt(s) and the Water Pump Mounting Hole(s) with good strength bolts. We actually ran the chain though two bolts for the pick-up and also bolted the slack ends into two additional holes for safety purposes. They might not have been the best places but without the heads we could grab the motor real low and didn't even need to remove the hood. Without the top end the motor is very light.
If you grab it by the head bolts on the mating surface make sure you do something to avoid having the chain damage the top of the block (if you intend to use it again).
Sincerely,
Kurt & Derek
Old Jun 3, 2005 | 07:45 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I used the accessory/exhaust bolt holes on mine.. works just fine. We also did that with my cousin's FE (ford) engine, and it uses the same size bolts (9/16) and the damn thing weighs more than a BBC does, I'm sure.
Steve78LT
Feb 24, 2016 12:15 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Mickeyruder
Sep 2, 2015 02:45 PM
madsv1000
Aug 20, 2015 06:45 AM
86White_T/A305
Aug 17, 2015 12:16 AM
