Swapping 305 Carburated To 305 FI
Old May 30, 2005 | 02:32 AM
83TAProject's Avatar
Car: 83 Transam
Engine: 305 4BBL
Transmission: TH700R4
Can anyone help me, i want to swap my 305 carb to a 305 fi out of a 85 Iroc Camaro, with harness and comp, is this possible?.
Old May 30, 2005 | 09:18 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
Completely possible. You simply need to swap everything that attaches to or feeds the engine (except the transmission, that is). Label everything as you disconnect or remove, keep sensors attached to the wiring harness and remove them from the car itself. Don't cut any wires, figure out where they go and disconnect at connectors.
You'll need all of the harness including the computer under the dash and some harnessing and relays from under the dash, all of the fuel system including the in-tank fuel pump, all of the exhaust (although this is a perfect opportunity for headers and performance exhaust upgrades).
xkingcodex
Feb 12, 2020 07:43 PM
Cleotiz
Jan 6, 2018 08:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
