ls6 to v6 Camaro
Old Jun 8, 2005 | 12:08 AM
JavaDude's Avatar
Car: 91 Camaro
Engine: V6 3.1 L
ls6 to v6 Camaro
Thinking to get ls6 instead of ls1...but dont know if ls6 has the same engine mount as ls1?
I bought 99 ls1, when arrived I cheked the engine block it is 98.
Now I just want to get new ls6 engine.
I need your opinion here guys....
Old Jun 8, 2005 | 01:41 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Do you know the difference between the two?
Ok first off the only main difference between the blocks are windage holes which are cast into the ls6 block. The did this so air could move easily through the lower end.
Cam, Heads, and intake are the only other dofference.
So yes the motor mounts are the same. And you can mis match parts for it to. Ie ls6 heads on an ls1. You can even use the caddy 6.0 escalade heads if you think your going to run a blower cause they flow the same as an ls6 head but have bigger combustion chambers.
Not sure what you want out of this motor but I would just stick with the ls1.
Old Jun 8, 2005 | 01:42 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Ok i just read what I posted and I dont mean to sound like an ***. Not my intention at all
Old Jun 8, 2005 | 05:58 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would stick with the LS1 motor that you have now. LS6 motors aren't easily found and the fact that they came in Z06 vettes really jacks up the barganing costs. The core you have now is fully capable of making serious power with little mods.
Old Jun 8, 2005 | 06:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What did you use to identify the engine as a '98? It's very possible (likely, even) for a '99 model year engine to have been built in 1998.
Old Jun 8, 2005 | 06:21 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Or if you really want an ls6 block most 01-03 Camaro or Corvettes have them even though there ls1's. Gm just started using some ls6 blocks instead of casting two of pritty much the same block.
Old Jun 8, 2005 | 06:25 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Best way to find out if it's a 98 or 99 is check the valve cover bolt pattern, 99+ are centerbolt and the 98 are perimeter bolt. Unless the heads were changed.
Old Jun 8, 2005 | 06:27 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
I thought all ls1's had center bolt valve covers.
Old Jun 8, 2005 | 06:37 PM
Klortho's Avatar
Car: 1987 GTA
Casting Number 806 or 933
LS1 (Perimeter Bolt)
97-98 5.7L Passenger Car and Corvette
Material: Aluminum
Combustion Chamber Volume: 66.67cc
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Casting Number 853 or 241
LS1 (Center Bolt)
99-00 5.7L Passenger Car and Corvette (853)
01+ 5.7L Passenger Car and Corvette (241)
Material: Aluminum
Old Jun 8, 2005 | 11:12 PM
JavaDude's Avatar
Car: 91 Camaro
Engine: V6 3.1 L
The way I found out its 1998 is when I separated the trany and open the back cover I can see there are two small holes for the oil galey not one medium size hole.
I checked the laser print sticker on the back of the block the number says "W...".
W -- 1998
X -- 1999 and so on..
the heads came with center bolts not parameter bolts.
The coils mounted on the brackets not individualy mounted.
It looks like that the heads had been changed to early model.
Old Jun 9, 2005 | 06:28 AM
Klortho's Avatar
Car: 1987 GTA
If the heads have centerbolt valve covers then it is a 99+ model.
Old Jun 9, 2005 | 09:20 PM
JavaDude's Avatar
Car: 91 Camaro
Engine: V6 3.1 L
what about LS2 are they the same engine mount with ls1?
Old Jun 9, 2005 | 09:27 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Same engine mounts/location but slightly different motor.
Old Jun 9, 2005 | 11:00 PM
JavaDude's Avatar
Car: 91 Camaro
Engine: V6 3.1 L
I bought some parts for Ls1 engine swap (walbro fuel pump, engine mount, vats adapter, tach adapter). Can I still use those parts for Ls2 Engine ?
Old Jun 9, 2005 | 11:01 PM
JavaDude's Avatar
Car: 91 Camaro
Engine: V6 3.1 L
Is Ls2 will fit nicely like Ls1 to my camaro?
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Jz canada
Dec 30, 2009 08:10 AM
five7kid
Feb 7, 2009 10:28 PM
