Approx Holley Stealth Ram cost
Old Jun 16, 2005 | 12:59 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
I'll tell you alittle bit about my set up I'm running, xr 282 cam, vortec heads (machine work done), scatt crank,1.6 rockers and so on. I'm expecting 430-450 at the crank.
Here's my question
Go carbed with a Holley 750 and an Rpm air-gap intake
^^^approx cost=700$ ^^^
or
Holley stealth Ram =cost including the whole set up running vortec heads.?
Old Jun 16, 2005 | 03:04 PM
Car: 2002 SS
Engine: Ls1
Would I have to buy the hole 2000+ kit?
Old Jun 16, 2005 | 07:13 PM
88 Ram Air TA's Avatar
Engine: 305 5.0L F engine code
No you do not have to buy the whole kit. If you just want to do the bare essentials here are the parts and cost.
Stealth Ram manifold #7540 (summit racing) $299.95
Fuel rail kit w/regulator #534-186 (summit racing) $215.39
Fuel line kit (supersportperformance) $119.99
Water neck MrGasket #2661 (PIC) $13.99
Flex hose upper radiator Advance Auto 12228 (PIC) $10.65
Intake gasket $12.99
Antifreeze (1 gallon) $7.99
Permatex Blue Silicone $3.99
5/8" hose barb for heater hose 1/2" thread $2.99
Total $687.93
I got this from Stealthram.com
Old Jun 16, 2005 | 07:17 PM
Car: 2002 SS
Engine: Ls1
what about the TB
Let me make it more clear. I'm trying to see if i can go with the stealth ram rather then carbed for around the same price. I see 2000 for the kit , how can 687 be everything i need when they have 2000 its such a big diff
Old Jun 16, 2005 | 07:29 PM
Car: 2002 SS
Engine: Ls1
like everything in this pic
Old Jun 16, 2005 | 07:32 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
You have Vortec heads? I dont think the HSR bolts up to those heads???
Old Jun 16, 2005 | 07:35 PM
Car: 2002 SS
Engine: Ls1
Holley StealthRam Intake Manifold & Base Plate for Vortec style Cylinder Heads. (Stock Fuel Rails not compatible, must use Holley Fuel Rails) $299.99
They make them now for vortecs as well
Old Jun 16, 2005 | 08:47 PM
Car: 2002 SS
Engine: Ls1
88 ram air ta, what about a throttle body
Old Jun 16, 2005 | 09:04 PM
Car: 2002 SS
Engine: Ls1
looks like id need the whole kit to me, cause i need everything in it.. the harness etc
Old Jun 16, 2005 | 10:05 PM
You do need a throttle body. They usually run about $400. You could use your stock computer and harness if you can tune cars. You will still have to tune the computer if you get the computer in the kit. But I think it is a little easier to tune.
I wish I was where you are at. I haven't even decided on what I am going to do with my engine yet. I want to finish my Interior before I move on the engine.
Old Jun 16, 2005 | 10:20 PM
Car: 2002 SS
Engine: Ls1
Yeah I pretty much finished up my looks (still a few odds and ends) and now i'm all about getting this 350 vortec done with the t56. I think i may just go carbed... cheaper
Old Jun 17, 2005 | 11:50 PM
ChevyRacer's Avatar
Car: 86 Camaro Iroc-Z
Engine: 355 TPI
no buy all the parts then get a used stock harness. Will still be close to $700 but not less...
Old Jun 18, 2005 | 10:28 AM
Car: 2002 SS
Engine: Ls1
687 + the tb 400$ = 1087
Upper and lower intake manifolds ? I would really like to go this route but i wouldnt like to exceed 1200
Old Jun 18, 2005 | 10:37 AM
Car: 2002 SS
Engine: Ls1
thats not including I need injectors , probably a better effecient intank fuel pump. It's really lookin like carbed imo Just cause i'm 17 on a budget.. later on I may go FI when i have the money. This dun look like its workin out with my $$
Old Jun 18, 2005 | 03:23 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
like i explained over at stealthram, you'll need everything as you are converting from a 2.8 v6. nothing you have, except for maybe the fuel pump, will work.
RedLeader289
May 28, 2019 01:47 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
Damon
Sep 26, 2015 04:29 PM
