Where to buy a 350 TPI ?
Well, im pretty sure the 350 TPI would be the best engine to put in a 89' RS v8. So I can't seem to find any place that sells 350 tpi's. So if anyone has some links where I can buy a 350 tpi crate motor, post em.
thanks
thanks
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
if you're going to spend time to put an L98 in the car, which you will have to change the ecm as well, why not go ahead and get an LT1, more power and better fuel efficency as well for about the same price.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by shr0olvl
where can you buy an LT1 crate motor then ?
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Re: Where to buy a 350 TPI ?
thanks
thanks
