LT1 for cheap what do you think?
Old Jul 21, 2005 | 11:56 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
http://www.winnipegheights.com/forum...ad.php?t=80716
k so theres the link do you think i should buy it, i have a 88 tpi setup now, would it be hard to make it work ?
Old Jul 22, 2005 | 12:06 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Link wont work unless registered.
Making it work and "hard" depends on your skills, pocket, and how determined you are. Im working on making everything available so its a plug and play deal.....
Old Jul 22, 2005 | 12:12 AM
IROC_5796's Avatar
heres a different link but should work clarity kinda sucks, free pic posting
http://d3v.yafro.com/photo/9157248
its 500 CAD and my car is totaly stripped right now
Old Jul 22, 2005 | 01:22 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
New link doesnt work either, if its complete 500 cdn is a pretty decent deal, to make it work "right" with your T5 if you plan on keeping that, you'll need to run a 92-93 computer, as you can see in my sig I do offer the hoses to hookup to your car with no trouble. The other differences are in the wiring, you can splice a stock harness to work, however IMO the fitment will never be that great, unless you spend too much time on it, and well in that case you've spent too much time on something with a bunch of splices, thus why im working on the plug and play harnesses, which will put the computer in the stock location as opposed to under the hood like a 4th gen.
Old Jul 22, 2005 | 07:22 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Well, you will be looking at about 300 bucks for a TB, another 350 for an Opti, probably 300 for a waterpump, maybe 100 for fuel rails, about 250 for injectors, 50 or so for an oilpump, then you will have to get the accessory bracket, 4th gen PS pump, ac (or ac delete pully) alternator, PCM, wiring.
So, 500 CAD = 410 USD, plus everything you would be looking at spending over 2000 USD for the motor and everything to complete it, which comes out to around 2,400 CAD.
Old Jul 22, 2005 | 11:44 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Or being that most get a used longblock around here buying those parts would be more like:
Throttle body $45
Fuel Rail $50
Injectors $75
Opti $60
Water Pump $30
Front Bracket $50
Alt $75
PS pump $30
PCM $100
Wiring - depends on what you go with but to get what you'd get with your normal pullout $150
So $665 not counting your ac delete pulley or idler which either a used compressor, or new delete pulley will both be around $60
So a little over 1k usd for a rebuilt longblock, not super high, not dirt cheap, good price i'd say for sure.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
wanext
Oct 6, 2015 12:18 AM
Damon
Sep 26, 2015 04:29 PM
