I know, another engine swap question...
Old Jul 27, 2005 | 03:44 PM
littlekings's Avatar
Car: Dirt Street Stock oval track 2bbl
Engine: 350 w/dart iron heads and 383 w/world products sportsman II heads
Transmission: saginaw
I am removing an 88 TBI 305cid and installing an old style 2 piece rear main seal 383cid. Am I correct in considering the following?
1. I will need a flywheel to fit the old style crank but the tranny will fit pilot bushing of any year. It is a 5 speed manual. Pressure plate should bolt onto old style flywheel.
2. Can I remove the TBI alltogether and run a mechanical fuel pump off the same fuel line, put on an Edelbrock intake and Holley carb?
3. Will the 305 radiator handle a slightly built 383cid?
Old Jul 27, 2005 | 04:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes on the clutch questions. A 153-tooth flywheel should do the trick. However, you'll either need an interally-balanced 383 crank, or an external balanced flywheel.
If you remove the TBI, you're best to either use a return-style regulator and run the in-tank pump, or drop the tank and remove the in-tank pump and run a mechanical pump. You could run the in-tank pump, mechanical pump, and return style regulator. Or, in-tank pump, and mechanical return-style pump.
A 305 radiator in good condition should handle a mild 383.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
