Big Block motor mounts
Old Aug 2, 2005 | 11:02 PM
Duke901's Avatar
Car: 89 Formula
I have heard a couple of things, one is that i can use the stock frame mounts and stock small block, block mounts, and the other that i heard is that i can use the stock frame mounts and use big block motor mounts. So is it true that i can use the stock block and frame mounts from the small block on my big block. Or do i have to get big block mounts.
Mike
Old Aug 3, 2005 | 02:16 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Yes, the stock CSB engine mounts will work with the CBB. You probably want to buy a new heavy duty pair.
Old Aug 3, 2005 | 02:22 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
urethane small block mounts like those from energy suspension are even better for the extra weight and twist that you're gonna give it......
Old Aug 20, 2005 | 08:43 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
If you are going with Hooker 2226 headers use the sbc frame mounts and engine side mounts. The bbc engine side ones I had didn't leave enough room for the headers.
Old Aug 20, 2005 | 11:33 PM
Duke901's Avatar
Car: 89 Formula
Ya i have the hooker headers. And i do have the stock mounts for the frame and block. So i should be alright i hope lol
Old Aug 22, 2005 | 11:04 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
no, not stock, unless you're running a decent stall to take the stress off of the mounts. use the stocke clamshells (block mounts) but use urethane frame mounts.
Old Aug 22, 2005 | 11:39 PM
Duke901's Avatar
Car: 89 Formula
im running a 3000 stall. Right now im kinda low on money so i might have to use the stock mounts.
Old Aug 23, 2005 | 11:25 AM
Car: 1982 Trans Am
Engine: 383 chevy
you have a loose enough converter, you shouldn't break them anyway. I ran the poly ones because i had the money, and my stall is only a 2400. still a pretty big KA-THUNK when it goes into gear. use a poly trans mount, when you get the funds, though. you'll break those left and right.
Old Aug 23, 2005 | 07:12 PM
Duke901's Avatar
Car: 89 Formula
Ok cool, do you have the part numbers.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
sreZ28
Aug 14, 2015 07:48 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
