BBC radiator fans?
Old 08-08-2005, 03:41 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
BBC radiator fans?
What radiator fans are you using with your BBC. I am using the long water pump for my pulley setup and it isn't leaving much room for elecric fans.
Old 08-08-2005, 05:32 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
If you don't have the AC condensor, you could put pusher fans on the front of the radiator.
Old 08-08-2005, 05:36 PM
Blackroc86's Avatar
Car: 1986 Iroc
I don't have the AC condensor but from what I have read the pusher fans aren't as efficient as the pullers.
Looks like I will have to lower the bottom rad tray about 1.5 inches so the 31X19 Griffing rad will stand up straight in there. Hopefully that will give me enough room to have some choice in fans.
I was hoping not to have to do that but might be the only way with the lwp.
sheachopper
07-31-2019 11:27 AM
Fanatic1074
10-02-2015 03:47 PM
Quick Reply: BBC radiator fans?
