Engine Swap Question
Old Aug 20, 2005 | 04:27 AM
No1Rs92's Avatar
Engine: EFI 305
this winter i wanna get the engine swapped out of my 92 rs its a 305 tbi..i was gunna buy a crate motor for it i was thinking about goin with the 330HP / 350 Deluxe GM Performance Parts Crate turn key Engine Assembly. its $5000.. now if i got that what else would i need exactly to get this thing put in my car and runnin right..any help apreciated...
Old Aug 20, 2005 | 07:10 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I purchased my 350 HO Deluxe from Jeg's for much less than $5000, so price around before you buy. You'll have to ditch the computer--check the following link for a small problem with cruise control:
https://www.thirdgen.org/techbb2/sho...hreadid=310552
And some of the accessory bracketry will have to be modified to fit. The motor comes with a flexplate, so if your car is a manuel, you'll need to purchase a flywheel (I went with the GM light weight flywheel). The motor comes with a 14x3 filter. To get my hood to close, I had to reduce the filter to 14x2 1/2. Though this has nothing to do with the motor, I also decided to go from belt to GM dual electric fans. Check this link:
https://www.thirdgen.org/techbb2/sho...hreadid=309711
JamesC
Old Aug 22, 2005 | 07:56 PM
No1Rs92's Avatar
Engine: EFI 305
james c could u possibly give me a list of all the things ill need to get it runnin in my car and a est price? id appreciate it thanks.. And hows it run it fast?
Old Aug 23, 2005 | 10:29 AM
JamesC's Avatar
The motor is pretty much a turn-key, so you don't need much:
motor
exhaust manifolds (might as well do exhaust: Hooker heads, Catco hi-flow cat, and Hooker catback)
flywheel (if your car is a manual)
starter (?)
You should be able to use all your accessories and their brackets (though I suspect modification will have to be done--at least my 85 IROC required it).
I don't have a clue on price. All will depend on where you purchase the motor and whether you do it or a shop--and their hourly rate. And there will be a ton of little things, which all cost: hooking up accelerator and cruise, moding the fuel line to carb, finding a banjo bolt so that the air cleaner will fit over the fuel line, locating a 14x2 1/2 filter so that the hood will close. You may find that your motor mounts are shot and need replacement and so on. Long story short, while the motor will pretty much drop into place, there are a ton of expenses that you'll only discover as you proceed.
The whole business was kind of a pain, but the effort is worth it. Baby hauls
JamesC
Old Aug 23, 2005 | 07:46 PM
ammoblows's Avatar
Car: 1982 Z28 Indy Pace Car
Engine: 350 HO 4bbl
Transmission: TH350
How did you hook up the TV cable???
I just put a 350 HO 4bbl into an 82 z28. I have everything hooked up except the TV Cable...the braket won't work or I just don't know how to attach it. I have a holley 600 on it. I also bought one of those aftermarket throttle cable brackets with the dropdown piece on it in hopes that I could attach the cable to it but it still won't reach....anybody know how to solve my little problem? Thanks in advance. Jason
Old Sep 12, 2005 | 12:19 PM
No1Rs92's Avatar
Engine: EFI 305
where do i get the wire harnesss and computer
Old Sep 12, 2005 | 12:27 PM
JamesC's Avatar
No computer. Use only the part of the stock harness that you require.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
