Going to a 383 and had a question
Old Aug 23, 2005 | 09:11 AM
kaylin4u's Avatar
Okay, I've decided to stroke my 355 to a 383. First I have a stock 1988 GTA flexplate and balancer. My crank I purchased is "externally" balanced 1pc rear seal. Can I use the following on my current flexplate?:
http://www.speedwaymotors.com/xq/asp...qx/product.htm
I found this on a post here.
Also, what size harmonic balancer should I use? The 8" or 6" balancer?
Basically I'm hoping to get some expertise from people here who have done the same 383 setup I'm attempting.
Old Aug 23, 2005 | 07:07 PM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
If your rotating assembly was balanced with that harmonic balancer and that flex plate you cant swap em without having it re-balanced. Thats what ive always practiced and have been told.
Old Aug 24, 2005 | 09:27 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Going to a 383 and had a question
No, that's for a 2-piece rear main seal crank (see the reference to 55-86).
Use the one that lines up with your timing tab.
five7kid's Avatar
Not true as long as the damper and flex plate were not modified during the balancing process.
Cameeeero
Sep 18, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
