Put on mech fuel pump...still no gas to carb!
Old Aug 28, 2005 | 06:07 PM
ammoblows's Avatar
Car: 1982 Z28 Indy Pace Car
Engine: 350 HO 4bbl
Transmission: TH350
I have an elec fuel pump in the tank. Does not work. Pulled the fuse, hooked back up my mech pump that I had on before I put the motor in the car, No fuel flowing. Put gas in carb, turned key car started then shut off...still no gas flowing. I did this about four or five times with the same result. I guess my question is, will the mech pump pull fuel through the elec pump in the tank? I am trying to avoid dropping the tank just to pull it out! Any ideas? How should I prime the pump or get fuel pumping? Thanks.
Old Aug 28, 2005 | 07:29 PM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
Cut a hole in your trunk, remove you in take pump, and stop trying to pull fuel through it.
Old Aug 28, 2005 | 08:08 PM
ammoblows's Avatar
Engine: 350 HO 4bbl
Transmission: TH350
Thanks but NO thanks, I would rather drop the tank than to do a crappy job involving cutting a hole in the floor just to get to the fuel pump. May be easier but that don't make it right.
Old Aug 28, 2005 | 08:10 PM
Transmission: th350
Good than you know you shouldnt be trying to pull fuel through your in tank pump. Just drop the tank and make your own pick up.
Old Aug 28, 2005 | 08:14 PM
ammoblows's Avatar
Engine: 350 HO 4bbl
Transmission: TH350
Reason I ask is because I read somewhere on this site, don't remeber where...but someone else said that they did it and had no problems.
Old Aug 28, 2005 | 08:15 PM
Transmission: th350
Just drop the tank and do it the right way.
Old Aug 28, 2005 | 08:17 PM
ammoblows's Avatar
Engine: 350 HO 4bbl
Transmission: TH350
Old Aug 28, 2005 | 10:02 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
this is how i did it, just pulled the pump and extended the pickup using a piece of 3/8" fuel line and a compression fitting.
yeah, do it right and pull the tank. grab a buddy and a 6 pack and make it a saturday afternoon job.
Old Aug 28, 2005 | 10:41 PM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
Re: Put on mech fuel pump...still no gas to carb!
I have an elec fuel pump in the tank. ........How should I prime the pump or get fuel pumping? Thanks.
Ammoblows,
A couple dozen (+/-) revolutions of the camshaft will provide all the pull you need to get fuel to the pump.
I'm glad to read you decided not to Hack the trunk. In order to remove the pick-up assy. You would have to make an ENORMOUS hole in the car and sacrifice safety for a few hours of work. I just pulled the tank in my son's '82 a few weeks back and it was not that bad. The problem with the '82 is the one-piece filler neck. Unfortunately, for those of us with '82's '83's and '84's (I think on '84) we have a heck of a lot harder time than the later models where the filler neck can be removed. You'll probably have to remove the muffler to get the tank out.
#1 - Remove the suspension cross links (2).
#2 - Remove the three heat shields (1 large, 2-small)
#3 - Disconnect the lines (4) above the rear tire at the front of the tank and remove the gas cap.
#4 - Remove the muffler & exit exhaust (hopefully not welded)
#5 - Disconnect the electrical connection: Pink, Black w/Stripe, Brown (driver's rear tail lamp area on an '82 Z-28).
#6 - Support the tank (hopefully empty) and remove the staps
#7 - Pull down and out toward the pass rear tire.
#8 - Remove the Pick-up assy with a brass punch or non-sparking tool.
#9 - Remove the pump and replace it with a length of hose.
#10 - Label the ends of the pick-up assy. lines (where they will hook up to you vehicle's chassis lines) before you put it back in!
With the help of a friend could be done PROPERLY in an afternoon.
Sure wish you were closer to Atlanta.... I'd be there in a minute to help ya.
Sincerely,
Kurt
Old Aug 29, 2005 | 01:20 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I think nit's funny when people say don't put in an access hole in the hatch to reach the fuel pump. drop the tank and do it right. GM dropped the ball on this as my 99 GP HAS this access panel in the trunk for jsut such access. IF done right, there shouldn't be any problems, and there are plenty of people/links to those who have done it & not killed themslves or the car.
Old Aug 29, 2005 | 07:51 AM
Car: 1982 - Z28
Project 85,
How do you do something like this right? IMPO - YOU CANT!
In order to remove the pump/pick-up assy (without cutting the lines) one would have to cut an ENORMOUS HOLE in the trunk area in order to wiggle the pick-up assy out (the leads are over 24" long and the pick-up is 12"+). It can't be done with a 6" or even a 12" hole... The guy that owned our Z-28 before us cut a hole 6" x 12" and he STILL COULDN'T GET IT OUT without clipping the lines and splicing them back together with rubber hose. We couldn't install the new (non-butchered) pick-up assy in that enormous hole without dropping the tank.
Did GM make a mistake? SURE AS HECK DID! Should they have an access port with provisions to disconnect the lines near/at the hole? Absolutely! But they didn't...... IMPO -The ONLY way to do the job PROFESSIONALLY & SAFELY is to REMOVE THE TANK!
I know I wouldn't want to be rear ended in a Camaro with the trunk hole modification..... Anybody old enough here to remember the Ford PINTO?
Sincerely,
Kurt
Old Aug 29, 2005 | 12:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
An important point here is that the GP has a trunk...
Old Aug 29, 2005 | 12:47 PM
five7kid's Avatar
From what I've observed from testimony on this Board, it is about 50/50 - half don't have any problem, half do.
Old Aug 29, 2005 | 04:48 PM
Engine: 5.7 / 7.4
doesn't mean I didn't cuss a whole lot when I saw the access panel
Old Aug 31, 2005 | 07:39 PM
ammoblows's Avatar
Engine: 350 HO 4bbl
Transmission: TH350
Got it all lined up gents, dropped the tank, pulled the pump, installed mech pump up front, re-routed fuel lines...she is good to go no on fuel. Only thing left is the tv cable bracket which I just ordered from summit. Should be on the road in a matter of days now. Next comes paint, interior, sound system, etc... Thanks
Old Aug 31, 2005 | 10:56 PM
Car: 1982 - Z28
....she is good to go no on fuel.
Ammoblows,
I HOPE that is supposed to read: "she is good to go noW on fuel"
Pulling the tank wasn't that bad was it?
Sincerely,
Kurt
Old Sep 1, 2005 | 06:19 PM
ammoblows's Avatar
Engine: 350 HO 4bbl
Transmission: TH350
Just missed a letter. It all worked out. Thanks.
92camaroJoe
Jul 29, 2023 07:57 PM
Jae992
Aug 27, 2015 09:07 AM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
