cams
Car: 1995 Firebird Formula
Transmission: Th350/4k stall
Axle/Gears: 10 bolt with 3.42s
cams
Im in the process of building a 305 to go in my 92 camaro. Im putting KB silvolite pistons, and porting the stock heads for now. I will also be running a edelbrock 600 cfm carb and a rpm air gap intake and possibly a small shot of nitrous. I was hoping I could get some help on what kind of roller cam I should run to get decent performance.
Transmission: 4L80E/4L80E
Welcome aboard.
What stock heads do you have? If LO3 TBI, don't bother.
A Comp Xtreme Energy in the 268 range would probably fill the bill. I'm not sure the exact designation on a roller, but that's the general range.
im planning on junking the stock heads for some of the high lift vortecs in like 6 months
