305 TPI to L98
Old Sep 21, 2005 | 05:44 PM
Mac II's Avatar
Car: 1994 Pontiac Trans Am
Engine: 5.7L V8 LT1
Transmission: 460LE A4
305 TPI to L98
Is this swap worth it? I'm quite curious. Is the 305 worth building or is a rebuilt L98 the way to go?
Old Sep 21, 2005 | 05:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
What are your goals? Are you trying to "fix" something, or do you just want more?
Most of the time, rebuilding a 305 isn't cost effective for the results compared to rebuilding a 350. However, sometimes what the 305 needs isn't a rebuild.
So, we need to know more of the background.
Old Sep 21, 2005 | 05:55 PM
Mac II's Avatar
Engine: 5.7L V8 LT1
Sorry for not clarifying. I meant working up the 305, the motor is in great shape. I dont even have the car yet, its a 91 TA. I'm 99% sure the car is going to be mine by the end of the week. I got some cash to dump, and I was wondering which route I should take.
Old Sep 21, 2005 | 06:36 PM
five7kid's Avatar
And you're sure it's TPI and not TBI.
First I'd do exhaust. Headers, 3" cat on back. Then PROM tuning.
Those are things you would have to do to get more out of the L98, anyway. Might as well start there. The 350 can come later.
After subframe connectors, poly bushings, brake upgrades, rear end gears and other upgrades, higher stall converter...
Old Sep 21, 2005 | 10:13 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
How much $$ do you have to spend? If the 305 is in good running shape i say keep it for now and spend the money on all the external upgrades, bc externally theyr exactly the same.
Headers back exhaust open up the intake side susp gears etc and when the block goes get that 350 b/c its gonna cost roughly the same to rebuild that 305 as a 350 so might as well do it right...
OTOH if youve got the $ and knowhow to do the swap get an LTx or LSx, but if an L98 comes your way for cheap its definetely worth looking into
Old Sep 22, 2005 | 12:41 PM
Mac3188's Avatar
Car: 1994 GMC SLE Jimmy
Engine: V6 H.O.
I definetly don't have the money for an LT1 or an LS1... since it'll be my first F-body, I'll drive it for a while, see what I want to do with it.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
