406 Swap
Old Sep 22, 2005 | 09:38 PM
FaSStcars's Avatar
Car: 1988 RS Camaro 1992 Z28 (crispy)
Transmission: 5 spd
406 Swap
Will a 400 SBC except a weighted 6 speed flywheel. The 400 is internally balanced I thought. So would the 6 speed flywheel need to be nuetral balanced.
Old Sep 22, 2005 | 09:43 PM
JesasaurusRex's Avatar
all stock 400s are externally balanced, all other SBC motors are internally balanced.
Old Sep 23, 2005 | 12:09 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
You have to buy a special flywheel for the 400. I got mine from centerforce.
Old Sep 23, 2005 | 12:34 PM
FaSStcars's Avatar
Transmission: 5 spd
How much did that flywheel cost from Centerforce. Just curious what the difference is between the Centerforce and the stock T56.
Old Sep 23, 2005 | 07:39 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
It was like 350 bucks. You need it for two reasons. You have a two peice rear main and it has to be externaly balanced. The stock lt1 flywheel wont even bolt up.
Old Sep 26, 2005 | 01:01 PM
FaSStcars's Avatar
Transmission: 5 spd
Hey thanks for your help. Did you mean that the 406 is a 1 piece rear main and the T56 flywheel is for the two piece rear main.
Old Sep 26, 2005 | 02:13 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
406 has a 2-piece rear main seal. T-56 (LT1 engine) have a 1-piece rear main seal. Have to have a flywheel specially designed for that swap. I installed an aluminuim flywheel from fidanaza. If engine is stock (externally balanced) you will need a balance plate to use the aluminuim flywheel I used. Centerforce steel fylwheel is balance already for externally balanced engine (383 400)
Old Sep 27, 2005 | 12:24 PM
FaSStcars's Avatar
Transmission: 5 spd
The car was an automatic before and I didn't see any weights on the stock flywheel. We did not build this motor, but it has been rebuilt. So I'm not sure if it was nuetral balanced or not. I would this it would have weight on the flywheel if it was externally balanced. The crankshaft does have a different bolt pattern than the t-56 flywheel though right?
Old Oct 4, 2005 | 12:08 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
yes it does cause its a two peice rear main where as an lt1 is a one peice rear main
Old Oct 5, 2005 | 04:13 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
You can internally balance a 400 block and use a regular 350 balancer - it costs more to do, but is much better for high perfomance use.
C409
Sep 23, 2015 04:30 PM
mddaniel
Sep 8, 2015 05:16 PM
trevor1010
Aug 26, 2015 02:41 PM
trevor1010
Aug 24, 2015 08:34 PM
Regal105
Aug 23, 2015 03:45 PM
