Motor mounts for V-6
Old Oct 15, 2005 | 02:32 AM
dennine3003's Avatar
Car: 1985 Camaro RS
Engine: v-8 5.0 tbi
Just switched engines in 89 Camaro from a v-8 to V-6. Cannot get motor mounts to line up! Tried putting motor mount bolts in first and then lining up and also tried the normal way, neither is working!! Ready to pull my hair out, please help!!
Old Oct 15, 2005 | 09:51 AM
CamaroKid89RS's Avatar
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
I just did the opposite of what you did, v6 to v8 swap. The v8 mounts are the forward most holes on the crossmember, and the v6 ones are the back most holes on the crossmember. Also the mounts between the two engine are different sizes, the v6 ones are smaller than the v8 ones. If you need v6 ones I can sell you mine if you'd like.
Old Oct 15, 2005 | 11:04 AM
Car: 1985 Camaro RS
Engine: v-8 5.0 tbi
I already bought new ones for the v-6. they wont line up and I have never had this much problems putting a engine in a car.
Old Oct 15, 2005 | 01:31 PM
Are you absolutely sure that the mounts are in the correct holes? That may be your problem.
Old Oct 15, 2005 | 04:44 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
this pic should help. Also, as I found out w/the v-8 mounts, turn the mount 180*. The holes on top are wider spaced than the holes on bottom.
https://www.thirdgen.org/techbb2/sho...hreadid=184409
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
