383 2 bolt main caps torque specs
Old Nov 7, 2005 | 03:24 PM
kaylin4u's Avatar
I'm building a 383 with 2 bolt mains (1 pc rear main seal) and was wondering what the torque specs should be on the main cap bolts and rod bolts.
On a 350, they usually say 70 ft/lbs for inner and 65 ft/lbs for outer on mains (on a 4 bolt main). Since this is a 2 bolt block, I'd think the 70 ft/lbs would be better. But big blocks usually say 95 ft/lbs.
On a 350, the rods are 50-60 ft/lbs.
Any suggestions?
Old Nov 7, 2005 | 03:31 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I just put the crank in my LT1 and it was torqued at 78 lb/ft
Reddeath210
Oct 6, 2015 08:20 AM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
