Serpente setup help on my vette motor swap
Old Nov 9, 2005 | 11:59 PM
GTA350JAG's Avatar
Car: 02 Z28, 78 Z28, 86 Iroc
Engine: 346 LS1, 350 Goodwrench, Vette 350
Transmission: M6, T 10, 700 R4
The serpente setup I have off a later iroc will not fit on the corvette motor. The bolt pattern on the head is slightley diffrent. Its the passanger side for the AC, tensioner, and smog pump. The only thing I can do is make a bracket which I really dont feel like doing but is their another alternative I can do. Has anyone had this problem?
86 Iroc w/ 87 vette motor
Serpente set up is off a 90 I think. Motor had no cold start injector but im sure that dosent matter should be all the same
Old Nov 23, 2005 | 04:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Bumping this back up.
I don't understand why you would have any problems mounting the serp setup, after removing the non-serp waterpump. Other than possibly needing to drill & tap one hole. Maybe someone else can provide some insight.
Old Nov 24, 2005 | 06:04 PM
GTA350JAG's Avatar
I got it on but thier is just one bolt that I couldnt get it. The only thing now is that I didnt realize the serp set up is off a trans am so the alternator and ac is on the wrong side... If anyone would want to trade me the setups let me know
Old Nov 24, 2005 | 08:29 PM
five7kid's Avatar
Model doesn't make a difference. With the serpentine, the alternator moved from the driver's to the passenger side.
Old Nov 24, 2005 | 09:41 PM
GTA350JAG's Avatar
oh damn so i guess I have to get origional belt set up
evilstuie
Jan 9, 2020 08:29 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Street Lethal
Aug 13, 2015 08:28 PM
