305 LG4 to a 350 EFI?
Old Nov 20, 2005 | 05:20 PM
Yossarian14's Avatar
Car: 1986 z28 and 1997 Disco
Engine: Lg4 305
I have a 305 LG4 is an 86 Z28 with a manual Transmission. I have already replaced my exhaust and deleted the cats. I want to replace the engine with a 350 and have it be fuel injected because I need decent mileage. Now is there any cheap way to do and if I were to go to a junkyard how hard would it be to find a TPI setup and swap it over? Is there any easier ways or complications I should know about.
Old Nov 20, 2005 | 11:19 PM
1981TTA's Avatar
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
If possible, I'd suggest getting hold of a "donor car" for your TPI swap. In addition to the hardware components in the engine bay, you'll also need the fuel pump/tank, lines from tank to fuel rail and multiple new harness odds and ends that won't be present on your carbed motor (IAC, injectors, etc).
The swap itself should be pretty straightforward. The final cost will depend on how cheaply you can get the above parts......
Old Nov 21, 2005 | 12:00 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Check out the info at
Http://www.chevythunder.com
You will se exactly what it will take to do the changover. I found the site very informative on all of the "little" things that can slow you down.
Plan the "system" installation. Do not consider it to be just adding some parts.
Things will go very smooth once you have a plan.
Old Nov 21, 2005 | 12:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Put a 350 under your LG4, use the money you don't spend converting to TPI to buy the extra gas the carb uses vs. EFI for the next 7 years.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
st.evel07
Aug 13, 2015 06:15 PM
