L98 to 355 4-bolt motor mount Q
Old Nov 22, 2005 | 04:48 PM
FiveSeven's Avatar
Car: 1988 Iroc Z
I currently have an L-98 in my IROC and I am going to be putting in a 1974 350 4-bolt main in a couple months. I need to know if the motor mounts are going to work, I figure they would since I am going from a 350 to another 350. Even if they do work would any of you suggest I buy new ones?
Old Nov 22, 2005 | 06:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
262, 267, 283 ('58-later), 302, 305, 307, 327, 350, 396, 400, 402, 427, 454 - all will mount up with the stock mounts.
It's a good idea to replace the chassis side while you've got things apart. I used poly myself, which only included the puck inside the mount shells. You need to drill out the rivets holding the shell together, put in the new "mount", bolt them back to the crossmember.
Old Nov 23, 2005 | 04:07 PM
five7kid's Avatar
It does make one wonder why you're going from a later 350 to a less capable earlier 350...
(Now, about that user name... )
Old Nov 23, 2005 | 07:27 PM
FiveSeven's Avatar
Car: 1988 Iroc Z
The reason is that my L-98 either broke a rod or spun the bearings, which is what I have been told but I haven't actually tore the motor down. My buddy is selling the motor from his s10 and it went 11.60s on motor and 10.80s on a 150 shot with AFR 180cc heads, which do not come with the motor. It went 12.30s with 200cc sportsman IIs and I'm going with Iron Eagles so I should be low 12s (hopefully).
Oh, and thanks for the info , and about the user name, I didn't spend too much time looking through posts before I joined so don't think I'm trying to copy ya, lol.
Old Nov 23, 2005 | 09:01 PM
five7kid's Avatar
Originally posted by FiveSeven
...so don't think I'm trying to copy ya, lol.
Nah, just jerking your chain...
Well, with a questionable block and available ready-to-go block, that makes sense. Had to ask, though, as some people don't make the most well thought-out decisions.
I'd highly recommend the poly mounts (and poly everything that's currently rubber).
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
