short block question
Old Dec 12, 2005 | 01:17 PM
fin170703's Avatar
Car: '87 iroc camaro
Engine: 350 L98
Transmission: 700-R4
Axle/Gears: 3.27 posi
Hi all
I am currently rebuildingmy L48 350 engine for camaro and the engine is now stripped down to the shortblock. The engine is in preaty good shape apart from a badly worn camshaft , 3 lobes had benn worn to a round shape ,. and a very slightly worn crank.
Now the engine is in bits im looking for a rebuild kit to suit my application but before i buy i was hoping to run a few things past you guys.
1. Is it worth regrinding the original crank or would it be worth investing in a new one while the engine is in bits ? as i said its not that bad but not to sure if the stock ones are up to much anyway ?
2. i live in the U.K and have finally found a supplier here that stocks these kits so this is what i'm going for http://www.americanv8engines.co.uk/?..._Rebuild_Kits.
Is this an adequate kit for for a street / strip application. I'm looking to get my motor to about the 330 bhp / 350 lbs torque mark so i need to make sure my bottom end is up to the task , i know its not massive figures but i want to be certain i'm doing it right as i dont plan on dropping the engine again in a hurry.
3. What duration could i go on a cam without making the car undrivable on the road ?
4. One of my biggest aims is to get the CR on my engine up past the 8.1 ratio. Am i right in saying that aftermarket pistons and heads can improve this if so then are the pistons in this kit up to scratch
Many thanks in advance for any help i recieve . Thanks. Craig
Old Dec 12, 2005 | 01:38 PM
fin170703's Avatar
Engine: 350 L98
sorry i can see i have put this in the wrong section.
Old Dec 12, 2005 | 05:42 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: short block question
1. It depends on what you have, and what you want from this motor. Does it have a cast or forged crank in it now? 330hp should be just fine on a stock crank in good shape. How high do you want this engine to spin?
2. That seems like a good quality kit, but with one HUGE exception... that camshaft is garbage. Its an old '60s GM grind that never really worked. Go with a more modern cam. I would suggest a Comp Cams XE274H. Other than the cam that comes with that kit, it looks like a good kit to use.
3. What induction system? EFI or carb? If you are using a carb, I'd go with something around 230* on both intake and exhaust, with a 110 - 112 LSA. For EFI, Comp Cams has a set of cams specifically meant to work with EFI.
4. Even with the stock pistons (which are a 12cc dish IIRC) you can boost the CR quite a bit by using heads with smaller combustion chambers. Your stock heads will have 76cc chambers. Getting heads with 62cc chambers and a stock gasket will give you around 9.5 CR, and a 58cc head will be about 10:1 CR with a stock head gasket.
anesthes
Mar 10, 2016 10:35 PM
Reddeath210
Oct 6, 2015 08:20 AM
camaro71633
Sep 1, 2015 10:24 AM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
